额定载荷Rated load | 0~10…2000kg | 精度等级Accuracy grade | C3 |
额定输出Rated outputt | 2.0±0.2%mV/V | 蠕变Creep deformation | ≤±0.03%F.S |
滞后误差Lag error | ±0.03%F.S | 线性误差Linear error | ±0.03%F.S |
零点输出Zero outputt | ≤±1%R.C | 重复性误差Repeatability error | ≤±0.01%R.C |
输入阻抗Input impedance | 385±35Ω | 输出阻抗outputt impedance | 350±3Ω |
绝缘电阻Insulation resistance | ≥2000MΩ | 破坏载荷Charge of surety | 150% |
输出温度影响outputt temperature effect | ±0.03%F.S/10℃ | 工作温度Temperature | (-20~70)℃ |
零点温度影响Zero temperature effect | ±0.02%F.S/10℃ | 材质Texture | 合金钢或不锈钢 |
力值变送器Force value transmitter | 4~20mA、0~10V | 额定电压Rated voltage | 5~15V DC |
微型柱式测力传感器
型号:
JFG-LP12
