品牌:ALPSALPINE(阿尔卑斯阿尔派)
尺寸:6.2mm×9.5mm
按键力度:1.57N
按键寿命:50万次
按键行程:0.25m
产品编号 | 型 | 动作力 | 操作方向 | 行程 | 操作寿命(5mA 5V DC) | 初期接触电阻 | 按钮颜色 | 尺寸(W×D×H) |
SKRGAAD010 | Radial | 1.27N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | Black | φ6.2mm×4.3mm |
SKRGABD010 | Radial | 1.57N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | White | φ6.2mm×4.3mm |
SKRGACD010 | Radial | 2.55N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | Gray | φ6.2mm×4.3mm |
SKRGADD010 | Radial | 1.27N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | Black | φ6.2mm×5.0mm |
SKRGAED010 | Radial | 1.57N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | White | φ6.2mm×5.0mm |
SKRGAFD010 | Radial | 2.55N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | Gray | φ6.2mm×5.0mm |
SKRGALD010 | Radial | 1.27N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | Black | φ6.2mm×7.0mm |
SKRGAMD010 | Radial | 1.57N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | White | φ6.2mm×7.0mm |
SKRGAND010 | Radial | 2.55N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | Gray | φ6.2mm×7.0mm |
SKRGAQD010 | Radial | 1.27N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | Black | φ6.2mm×9.5mm |
SKRGARD010 | Radial | 1.57N | Top push | 0.25mm | 500,000 cycles | 500mΩ max. | White | φ6.2mm×9.5mm |
SKRGASD010 | Radial | 2.55N | Top push | 0.25mm | 200,000 cycles | 500mΩ max. | Gray | φ6.2mm×9.5mm |
