--- 产品参数 ---
公司logo
Banana Pi开源硬件
116內容 |  18w+浏览量  |  393粉丝
--- 产品详情 ---
Banana Pi BPI-M2 Pro是Banana Pi公司于2021年推出的下一代单板机。它采用Amlogic S905X3四核Cortex-A55 (2.0 XXGHz)处理器。板载2GB LPDDR4内存和16GB EMMC存储,支持2个USB 3.0接口,1个千兆网口。板载RT8821CU wifi&BT。1 HDMI输出 905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持8K视频解码和8K视频输出,运行开放的安卓9.0系统和Linux系统。
BPI-M2 Pro与香蕉派 BPI-M2+ 一样大小,接口也一样,所以可以使用BPI-M2+的外壳。
硬件接口:
香蕉派BPI-M2 Pro 与香蕉派 BPI-M5 一样采用Amlogic S905x3芯片方案,但在尺寸与接口上完全与香蕉派 BPI-M2+一致,用BPI-M2+做产品的客户,可以直接升级替换。
硬件规格:
Banana pi BPI-M2 Pro 硬件规格
CPUAmlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz)
GPUMali-G31 MP2 GPU with 4 x Execution Engines (650Mhz)
Memory2 GB LPDDR4
StorageMicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB
Network10/100/1000 Mbit/s Ethernet
Wifi&BTDual-band 802.11 b/g/n/ac WiFi 5 1×1 and Bluetooth 4.2 via Realtek RTL8821CU
Video Output(s)1 x HDMI 2.0 (up to 4K@60Hz with HDR, CEC, EDID)
Audio Output(s)1 x HDMI digital output
USB ports2x USB 3.0 host ports, 1x micro USB OTG port
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
SwitchesReset, Power and U-boot
LEDPower Status and Activity status
Power Source5 volt @3A via DC port
Size & Weight65mm×65mm, 58g
OSAndroid and Linux
BPI-M2 Pro ,BPI-M5 , Odroid C4 , 树莓派4 规格比较表
BPI-M2 Pro VS BPI-M5 VS Odroid C4 VS RPI 4
香蕉派 BPI-M2 Pro
香蕉派 BPI-M5
Odroid C4树莓派 4
ProcessorAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzAmlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHzBroadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
GPUMali-G31 MP2 GPUMali-G31 MP2 GPUMali-G31 MP2 GPUBroadcom VideoCore VI
RAM2GB LPDDR44GB LPDDR4DDR4 4GiB with 32-bit bus width2GB, 4GB or 8GB LPDDR4-3200 SDRAM
Storagemicro SD card slot & 16GB eMMC flash on boardmicro SD card slot & 16GB eMMC flash on boardmicro SD card slot , eMMC connector for optionmicro SD card slot, non EMMC
Network1 GbE ,WiFi&BT5.0 onbardGbE ,Optional WiFi USB dongleGbEGbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
Video Output1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID)2 × micro-HDMI 2.0
Audio Output1 x HDMI digital output3.5mm jack and 1 x HDMI digital outputOptional SPDIF optical output3.5 mm analogue audio-video jack
DSIN/AN/AN/A2-lane MIPI DSI display port
CSIN/AN/AN/A2-lane MIPI CSI camera port
USBUSB 3.0 x 2 1 Micro USB 2.0USB 3.0 x 4 TYPE CUSB 3.0 x 4, 1 x Micro USB 2.0 port (OTG)2 USB 3.0 ports; 2 USB 2.0 ports;
Power5 volt @3A via DC power5 volt @3A via Micro USB (TYPE C)1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm)5V DC via USB-C connector (minimum 3A*)
IRYesYesYesN/A
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND).40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND).40 x GPIO pins40-pin GPIO header, populated
ButtonReset, user and U-bootReset, user and U-bootN/AN/A
LEDPower Status and Activity statusPower Status and Activity statusPower Status and Activity statusPower Status and Activity status
Dimensions & weight65mm x 65mm,58g85mm x 56mm, 48g85mm x 56mm 59g88 mm × 58 mm, 46 g
System SupportLinux & AndroidLinux & AndroidLinux & AndroidLinux & Android
BPI-M2 Pro 外壳设计:
在线开发文档:https://wiki.banana-pi.org/Banana_Pi_BPI-M2_Pro
