Banana Pi BPI-M2 Ultra单板计算机采用全志A40i/R40/V40 芯片方案设计,板载2G RAM内存和8G eMMC
型号: BPI-M2 Ultra 单板计算机
品牌: Banana Pi(香蕉派)
--- 产品参数 ---
公司logo
Banana Pi开源硬件
118內容 |  20w+浏览量  |  393粉丝
--- 产品详情 ---
香蕉派 BPI-M2 Ultra 四核单板计算机采用全志 A40i(可选R40/V40)芯片开发。支持板载Wifi与蓝牙,支持SATA接口,可以直接接硬盘。并且板载8G eMMC ,可以选择SD卡启动或从eMMC flash 启动。
Banana PI BPI-M2 Ultra 兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 和 全志Tina 系统.
Banana PI BPI-M2 Ultra硬件:全志A40i 四核处理器,2GB LPDDR3内存,千兆以太网口,3USB 接口 流畅运行Android5.1。Banana PI BPI-M2 Ultra 体积如信用卡大小,与BPI-M3尺寸一样,GPIO兼容Raspberry PiB+并能运行其ROM Image。
硬件接口示意:
硬件规格表:
香蕉派 BPI-M2 Ultra硬件规格书
主芯片Allwinner A40i/R40/V40
CPU主控quad-core cortex -A7,the most power efficient CPU core ARM‘s ever development
GPUdual-core MALI-400 MP2 and runs at 500MHz, capable of 1.1 Gpixel/s throughput. Graphics capabilities are slightly higher than the original Xbox’s level of performance. The GPU provides OpenGL ES 2.0, hardware-accelerated OpenVG, 1080p45 H.264 high-profile encode and decode.
SDRAM内存2 GB DDR3 with 733MHz(shared with GPU)
SATA 硬盘接口suppoort SATA interface
GPIO定义40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
有线网口10/100/1000Mbps Ethernet (Realtek RTL8211E/D)
Wifi 无线WiFi 802.11 b/g/n (AP 6212 module on board)
蓝牙支持BT4.0
Flash存储MicroSD (TF) card,8GB eMMC onboard
显示4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4
VideoMulti-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition(HD)H.264 video encoder is up to 1080P@45fps
Audio outputsHDMI, analog audio (via 3.5 mm TRRS jack)
Camera摄像头A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps
Audio inputOn board microphone
USB2 USB 2.0 host, 1 USB 2.0 OTG
按键Reset button, Power button, U-boot button
Led 灯Power status Led and RJ45 Led
IR红外控制onboard IR receiver
DC 供电5V/2A with micro USB port
电池接口3.7V lithium battery power support
尺寸85mmX56mm,same size as raspberry pi 3
Weight40g
在线wiki开发文档:
https://wiki.banana-pi.org/Banana_Pi_BPI-M2U
