--- 产品参数 ---
查看更多参数
公司logo
Banana Pi开源硬件
121內容 |  21w+浏览量  |  393粉丝
--- 产品详情 ---
香蕉派 BPI-M2 Berry 四核单板计算机采用全志 R40/V40芯片开发。支持板载Wifi与蓝牙,支持SATA接口,可以直接接硬盘。板上有SD卡插座,可以从SD卡启动系统镜像。
Banana PI BPI-M2 Berry 兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统和全志TinaLinux系统.
Banana PI BPI-M2 Berry硬件:全志R40/V40四核处理器,1GB LPDDR3内存,千兆以太网口,4 USB 接口 流畅运行Android5.1。Banana PI BPI-M2 Berry尺寸与树莓派 3完全一样,可以直接使用树莓派3的外壳。GPIO兼容Raspberry Pi 3并能运行rasbian 系统。
作为香蕉派家族的一员,BPI-M2 Berry是香蕉皮M1/M1+的直接升级版,支持SATA。
板子的尺寸与接口都和Raspberry Pi 3一样,所以你可以用树莓派3的外壳等配件直接用在BPI-M2 Berry
硬件接口:
硬件规格:
HardWare Specification of Banana pi BPI-M2 Berry
SocAllwinner R40/V40
CPUquad-core cortex -A7,the most power efficient CPU core ARM‘s ever development
GPUdual-core MALI-400 MP2 and runs at 500MHz, capable of 1.1 Gpixel/s throughput. Graphics capabilities are slightly higher than the original Xbox’s level of performance. The GPU provides OpenGL ES 2.0, hardware-accelerated OpenVG, 1080p45 H.264 high-profile encode and decode.
SDRAM1GB DDR3 with 733MHz(shared with GPU)
SATAsuppoort SATA interface
GPIO40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
On board Network10/100/1000Mbps Ethernet (Realtek RTL8211E/D)
Wifi ModuleWiFi 802.11 b/g/n (AP 6212 module on board)
BluetoothBT4.0
On board StorageMicroSD (TF) card,No eMMC onboard
Display4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4
VideoMulti-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition(HD)H.264 video encoder is up to 1080P@45fps
Audio outputsHDMI, analog audio (via 3.5 mm TRRS jack), I2S audio (also potentially for audio input)
CameraA CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps
Audio inputOn board microphone
USB4 USB 2.0 host, 1 USB 2.0 OTG
ButtonsReset button, Power button, U-boot button
LedsPower status Led and RJ45 Led
IRNo onboard IR receiver
DC Power5V/2A with micro USB port
batteryNo 3.7V lithium battery power support
Sizes85mmX56mm,same size as raspberry pi 3
Weight40g
在线Wiki开发文档:
 https://wiki.banana-pi.org/Banana_Pi_BPI-M2_Berry
