类型:电压, 电流
其他特性:低噪, 模拟, 锁定, 机架式
电压:10 V
功率:35 W (0 hp)
这个最高级的产品是被设计的一个模式封锁行动放大器测量与对使成为可能的全部更大的噪声级的用途的AC信号测量甚而nanovolts。 SR510 (单相)和SR530 (双重阶段)有低噪声电压和当前输入。 他们也有高动态储备、两阶段时间常数和内部振荡器。
the widest bandwidth lock-in amplifier available. It provides uncompromised performance with a frequency range of 25 kHz to 200 MHz and up to 80 dB of drift-free dynamic reserve. It includes the many features, ease of operation, and programmability that you've come to expect from SRS DSP lock-in amplifiers.
· 25 kHz to 200 MHz frequency range
· 80 dB dynamic reserve
· Time constants from 100 μs to 30 ks (6, 12, 18 or 24 dB/oct rolloff)
· "No Time Constant" mode (10 μs to 20 μs update rate)
· Auto-gain, -phase, -reserve and -offset
· Two 16-bit DACs and ADCs
· Internal or external reference
· GPIB and RS-232 interfaces
![](https://file.elecfans.com/web2/M00/63/66/poYBAGMC7KaAJRaGAAL8LeBdAQE365.png)
![](https://file.elecfans.com/web2/M00/63/66/poYBAGMC7KaAakG4AAMbCR3Ce64741.png)
![](https://file.elecfans.com/web2/M00/64/01/pYYBAGMC7KaAQDtOAAIcC8ansgQ733.png)
![](https://file.elecfans.com/web2/M00/64/01/pYYBAGMC7KaAYfiVAAI65diseBs108.png)
![](https://file.elecfans.com/web2/M00/64/01/pYYBAGMC7KaAYFiPAAGwXqg341o607.png)
