舞台灯,用于LED显示器,建筑和装饰LED照明,LED路灯
AP5 199
LED Driver
Description
The AP5199 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike AP5160,this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. The AP5199 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an External control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input.
特性:
快速平均电流控制
可编程恒定关闭时间开关
线性调光输入
PWM调光输入
具有跳跃模式的输出短路保护
环境工作温度-40至125度
与AP5199兼容引脚
应用:
● DC/DC or AC/DC LED driver applications
● LED backlight driver for LCD displays
● General purpose constant current source
● LED signage and displays
● Architectural and decorative LED lighting
● LED street lighting
