1 / 3
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  212粉丝
--- 产品详情 ---
200μA 电源电流、36V 电源精密仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 3
Input offset (+/-) (Max) (uV) 150
Gain (Min) (V/V) 1
Gain (Max) (V/V) 1000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 18
Features Cost Optimized, Small Size, Overvoltage Protection
CMRR (Min) (dB) 120
Input offset drift (+/-) (Max) (uV/C) 2
Input bias current (+/-) (Max) (nA) 65
Iq (Typ) (mA) 0.2
Bandwidth at min gain (Typ) (MHz) 1
Gain error (+/-) (Max) (%) 0.15
Operating temperature range (C) -40 to 125
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 0.1
Output swing headroom (to positive supply) (Typ) (V) -0.15
Input common mode headroom (to negative supply) (Typ) (V) 0
Input common mode headroom (to positive supply) (Typ) (V) -1
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 0.52
Gain non-linearity (+/-) (Max) (%) 0.002
  • Input common-mode range: Includes V–
  • Common-mode rejection:
    • 104 dB, min (G = 10)
    • 100 dB, min at 5 kHz (G = 10)
  • Power-supply rejection: 100 dB, min (G = 1)
  • Low offset voltage: 150 μV, max
  • Gain drift: 1 ppm/°C (G = 1), 35 ppm/°C (G > 1)
  • Noise: 18 nV/√Hz, G ≥ 100
  • Bandwidth: 1 MHz (G = 1), 60 kHz (G = 100)
  • Inputs protected up to ±40 V
  • Rail-to-rail output
  • Supply current: 200 μA
  • Supply range:
    • Single supply: 3 V to 36 V
    • Dual supply: ±1.5 V to ±18 V
  • Specified temperature range:
    –40°C to +125°C
  • Packages: 8-pin VSSOP, SOIC, and WSON
The INA826 is a cost-effective instrumentation amplifier that offers extremely low power consumption and operates over a very wide single-supply or dual-supply range. A single external resistor sets any gain from 1 to 1000. The device offers excellent stability over temperature, even at G > 1, as a result of the low gain drift of only 35 ppm/°C (maximum).
The INA826 is optimized to provide excellent common-mode rejection ratio of over 100 dB (G = 10) over frequencies up to 5 kHz. At G = 1, the common-mode rejection ratio exceeds 84 dB across the full input common-mode range, from the negative supply all the way up to 1 V of the positive supply. Using a rail-to-rail output, the INA826 is a great choice for low-voltage operation from a 3-V single supply, as well as dual supplies up to ±18 V.
Additional circuitry protects the inputs against overvoltage of up to ±40 V beyond the power supplies by limiting the input currents to less than 8?mA.
The INA826 is available in 8-pin SOIC, VSSOP, and tiny 3-mm × 3-mm WSON surface-mount packages. All versions are specified for the –40°C to +125°C temperature range.
