公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
高温低功耗精密仪表放大器
Number of channels (#) 1
Vs (Max) (V) 5.5
Vs (Min) (V) 1.8
Input offset (+/-) (Max) (uV) 25
Gain (Min) (V/V) 1
Gain (Max) (V/V) 1000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 50
Features Zero Drift, Low power
CMRR (Min) (dB) 80
Input offset drift (+/-) (Max) (uV/C) 0.1
Input bias current (+/-) (Max) (nA) 0.2
Iq (Typ) (mA) 0.198
Bandwidth at min gain (Typ) (MHz) 0.15
Gain error (+/-) (Max) (%) 0.5
Operating temperature range (C) -55 to 210
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 0.05
Output swing headroom (to positive supply) (Typ) (V) -0.05
Input common mode headroom (to negative supply) (Typ) (V) 0.1
Input common mode headroom (to positive supply) (Typ) (V) -0.1
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 2
Gain non-linearity (+/-) (Max) (%) 0.001
  • Low Offset Voltage: 25 μV (max at 25°C), G ≥ 100
  • Low Drift: 0.2 μV/°C, G ≥ 1000
  • Low Noise: 55 nV/√Hz, G ≥ 100
  • High CMRR: 100 dB (min at 25°C), G ≥ 10
  • Supply Range: +1.8 V to +5.5 V
  • Input Voltage: (V–) +0.1 V to (V+) –0.1 V
  • Output Range: (V–) +0.05 V to (V+) –0.05V
  • Low Quiescent Current: 198 μA
  • RFI Filtered Inputs
The INA333 is a low-power, precision instrumentation amplifier offering excellent accuracy. The versatile 3-op amp design, small size, and low power make it ideal for a wide range of portable applications.
A single external resistor sets any gain from 1 to 1000. The INA333 is designed to use an industry-standard gain equation: G = 1 + (100kΩ/RG).
The INA333 provides very low offset voltage (25 μV at 25°C, G ≥ 100), excellent offset voltage drift (0.2 μV/°C, G?≥?100), and high common-mode rejection (100 dB at 25°C, G?≥?10). It operates with power supplies as low as 1.8 V (±0.9V), and quiescent current is only 50 μA—ideal for battery-operated systems. Using autocalibration techniques to ensure excellent precision over the extended industrial temperature range, the INA333 also offers exceptionally low noise density (55 nV/√Hz) that extends down to dc.
The INA333 is is specified over the TA?=?–55°C to +210°C temperature range.
