公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
增强型产品精密低功耗仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 4.5
Input offset (+/-) (Max) (uV) 100
Gain (Min) (V/V) 1
Gain (Max) (V/V) 10000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 8
Features Current Feedback, Overvoltage Protection
CMRR (Min) (dB) 113
Input offset drift (+/-) (Max) (uV/C) 150
Input bias current (+/-) (Max) (nA) 8
Iq (Typ) (mA) 0.7
Bandwidth at min gain (Typ) (MHz) 1.3
Gain error (+/-) (Max) (%) 0.65
Operating temperature range (C) -55 to 125
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 0.8
Output swing headroom (to positive supply) (Typ) (V) -0.9
Input common mode headroom (to negative supply) (Typ) (V) 1.7
Input common mode headroom (to positive supply) (Typ) (V) -1.4
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 0.2
Gain non-linearity (+/-) (Max) (%) 0.0055
  • Low Offset Voltage
  • Low Input Bias Current
  • High CMR: 95 dB (Typical)
  • Inputs Protected to ±40 V
  • Wide Supply Range: ±2.25 V to ±18 V
  • Low Quiescent Current: 2 mA (Typical)
  • APPLICATIONS
    • Bridge Amplifier
    • Thermocouple Amplifier
    • RTD Sensor Amplifier
    • Medical Instrumentation
    • Data Acquisition
    • Supports Extreme Temperature Applications:
      • Controlled Baseline
      • One Assembly and Test Site
      • One Fabrication Site
      • Available in Military (–55°C to +125°C)
        Temperature Range(1)
      • Extended Product Life Cycle
      • Extended Product-Change Notification
      • Product Traceability
(1) Custom temperature ranges available
All other trademarks are the property of their respective owners
The INA129-EP device is a low power, general-purpose instrumentation amplifier offering excellent accuracy. The versatile 3-op amp design and small size make the device ideal for a wide range of applications. Current-feedback input circuitry provides wide bandwidth even at high gain (200 kHz at G = 100).
A single external resistor sets any gain from 1 to 10,000. The INA129-EP provides an industry-standard gain equation; the INA129-EP gain equation is compatible with the AD620.
The INA129-EP device is laser trimmed for very low offset voltage, drift, and high common-mode rejection (113 dB at G ≥ 100). It operates with power supplies as low as ±2.25 V, and quiescent current is only 750 μA–ideal for battery operated systems. Internal input protection can withstand up to ±40 V without damage.
The INA129-EP is available in a 8-Pin SOIC surface-mount package specified for the ?55°C to 125°C temperature range.
