Number of channels (#) | 1 |
Vs (Max) (V) | 5.5 |
Vs (Min) (V) | 2.7 |
Input offset (+/-) (Max) (uV) | 100 |
Gain (Min) (V/V) | 0.1 |
Gain (Max) (V/V) | 1000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 33 |
Features | Cost Optimized, Shutdown |
CMRR (Min) (dB) | 106 |
Input offset drift (+/-) (Max) (uV/C) | 0.4 |
Input bias current (+/-) (Max) (nA) | 2 |
Iq (Typ) (mA) | 2.4 |
Bandwidth at min gain (Typ) (MHz) | 0.001 |
Gain error (+/-) (Max) (%) | 0.2 |
Operating temperature range (C) | -40 to 125 |
Type | Resistor |
Output swing headroom (to negative supply) (Typ) (V) | 0.001 |
Output swing headroom (to positive supply) (Typ) (V) | -0.01 |
Input common mode headroom (to negative supply) (Typ) (V) | 0.25 |
Input common mode headroom (to positive supply) (Typ) (V) | 0.1 |
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) | 0.8 |
Gain non-linearity (+/-) (Max) (%) | 0.01 |
- PRECISION
LOW OFFSET: 100uV (max)
LOW OFFSET DRIFT: 0.4uV/°C (max)
EXCELLENT LONG-TERM STABILITY
VERY-LOW 1/f NOISE - SMALL SIZE
microPACKAGE: MSOP-8, MSOP-10 - LOW COST
- APPLICATIONS
- LOW-LEVEL TRANSDUCER AMPLIFIER FOR BRIDGES, LOAD CELLS, THERMOCOUPLES
- WIDE DYNAMIC RANGE SENSOR MEASUREMENTS
- HIGH-RESOLUTION TEST SYSTEMS
- WEIGH SCALES
- MULTI-CHANNEL DATA ACQUISITION SYSTEMS
- MEDICAL INSTRUMENTATION
- AUTOMOTIVE APPLICATIONS
- GENERAL-PURPOSE
The INA337 and INA338 (with shutdown) are high temperature, high-performance, low-cost, precision instrumentation amplifiers. They are true single-supply instrumentation amplifiers with very-low DC errors and input common-mode ranges that extends beyond the positive and approaches the negative rail. These features make them suitable for applications ranging from general-purpose to high-accuracy.
Excellent long-term stability and very low 1/f noise assure low offset voltage and drift throughout the life of the product.
The INA337 (without shutdown) comes in the MSOP-8 package. The INA338 (with shutdown) is offered in MSOP-10. Both are specified over the temperature range, -40°C to +125°C.
