公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
精密低漂移 CMOS 仪表放大器
Number of channels (#) 1
Vs (Max) (V) 5.5
Vs (Min) (V) 2.7
Input offset (+/-) (Max) (uV) 100
Gain (Min) (V/V) 0.1
Gain (Max) (V/V) 1000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 33
Features Cost Optimized
CMRR (Min) (dB) 100
Input offset drift (+/-) (Max) (uV/C) 0.4
Input bias current (+/-) (Max) (nA) 2
Iq (Typ) (mA) 2.4
Bandwidth at min gain (Typ) (MHz) 0.001
Gain error (+/-) (Max) (%) 0.2
Operating temperature range (C) -40 to 85
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 0.005
Output swing headroom (to positive supply) (Typ) (V) -0.005
Input common mode headroom (to negative supply) (Typ) (V) -0.02
Input common mode headroom (to positive supply) (Typ) (V) 0.1
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 0.8
Gain non-linearity (+/-) (Max) (%) 0.01
  • PRECISION
    ???LOW OFFSET: 100 μV (max)
    ???LOW OFFSET DRIFT: 0.4 μV/°C (max)
    ???EXCELLENT LONG-TERM STABILITY
    ???VERY-LOW 1/f NOISE
  • TRUE RAIL-TO-RAIL I/O
    ???INPUT COMMON-MODE RANGE:
    ??????20mV Below Negative Rail to 100mV Above Positive Rail
    ???WIDE OUTPUT SWING: Within 10mV of Rails
    ???SUPPLY RANGE: Single +2.7V to +5.5V
  • SMALL SIZE
    ???microPACKAGE: MSOP-8, MSOP-10
  • LOW COST
  • APPLICATIONS
    • LOW-LEVEL TRANSDUCER AMPLIFIER FOR BRIDGES, LOAD CELLS, THERMOCOUPLES
    • WIDE DYNAMIC RANGE SENSOR MEASUREMENTS
    • HIGH-RESOLUTION TEST SYSTEMS
    • WEIGH SCALES
    • MULTI-CHANNEL DATA ACQUISITION SYSTEMS
    • MEDICAL INSTRUMENTATION
    • GENERAL-PURPOSE
The INA326 and INA327 (with shutdown) are high-performance, low-cost, precision instrumentation amplifiers with rail-to-rail input and output. They are true single-supply instrumentation amplifiers with very low DC errors and input common-mode ranges that extends beyond the positive and negative rails. These features make them suitable for applications ranging from general-purpose to high-accuracy.
Excellent long-term stability and very low 1/f noise assure low offset voltage and drift throughout the life of the product.
The INA326 (without shutdown) comes in the MSOP-8 package. The INA327 (with shutdown) is offered in an MSOP-10. Both are specified over the industrial temperature range, ?40°C to +85°C, with operation from ?40°C to +125°C.
