公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
低噪声低失真 G=2000 仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 9
Input offset (+/-) (Max) (uV) 250
Gain (Min) (V/V) 2000
Gain (Max) (V/V) 2000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 1.3
Features Ultra-low noise
CMRR (Min) (dB) 100
Input bias current (+/-) (Max) (nA) 12000
Iq (Typ) (mA) 10
Bandwidth at min gain (Typ) (MHz) 0.45
Gain error (+/-) (Max) (%) 1
Operating temperature range (C) -55 to 125
Type Fixed Gain
Output swing headroom (to negative supply) (Typ) (V) 1.8
Output swing headroom (to positive supply) (Typ) (V) -1.8
Input common mode headroom (to negative supply) (Typ) (V) 3
Input common mode headroom (to positive supply) (Typ) (V) -3
Gain non-linearity (+/-) (Max) (%) 0.005
  • LOW NOISE: 1.3nV/Hz at 1kHz
  • LOW THD+N: 0.09% at 1kHz
  • WIDE BANDWIDTH: 450kHz
  • WIDE SUPPLY RANGE: ±4.5V to ±18V
  • HIGH CMR: > 100dB
  • GAIN SET WITH EXTERNAL RESISTOR
  • SO-14 SURFACE-MOUNT PACKAGE
  • APPLICATIONS
    • MOVING-COIL TRANSDUCER AMPLIFIERS
    • DIFFERENTIAL RECEIVERS
    • BRIDGE TRANSDUCER AMPLIFIERS
    • MICROPHONE AND HYDROPHONE
    • PREAMPS
The INA166 is a very low-noise, low-distortion, monolithic instrumentation amplifier. Its current-feedback circuitry achieves very wide bandwidth and excellent dynamic response over a wide range of gain. It is ideal for low-level signals such as microphones or hydrophones. Many industrial, instrumentation, and medical applications also benefit from its low noise and wide bandwidth.
Unique distortion cancellation circuitry reduces distortion to extremely low levels, even in high gain. The INA166 provides near-theoretical noise performance for 200 source impedance. Its differential input, low noise, and low distortion provide superior performance as a low-level signal amplifier.
The INA166 is available in a space-saving SO-14 surface-mount package, specified for operation over the \x9640°C to +85°C temperature range.
