公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
FET 输入低功耗仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 4.5
Input offset (+/-) (Max) (uV) 500
Gain (Min) (V/V) 1
Gain (Max) (V/V) 10000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 20
Features Overvoltage Protection
CMRR (Min) (dB) 106
Input offset drift (+/-) (Max) (uV/C) 5
Input bias current (+/-) (Max) (nA) 0.05
Iq (Typ) (mA) 0.45
Bandwidth at min gain (Typ) (MHz) 0.6
Gain error (+/-) (Max) (%) 0.5
Operating temperature range (C) -40 to 85
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 0.15
Output swing headroom (to positive supply) (Typ) (V) -0.9
Input common mode headroom (to negative supply) (Typ) (V) 2
Input common mode headroom (to positive supply) (Typ) (V) -2
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 1
Gain non-linearity (+/-) (Max) (%) 0.005
  • LOW BIAS CURRENT: ±4pA
  • LOW QUIESCENT CURRENT: ±450μA
  • LOW INPUT OFFSET VOLTAGE: ±200μV
  • LOW INPUT OFFSET DRIFT: ±2μV/°C
  • LOW INPUT NOISE: 20nV/sqrt(Hz) at f = 1kHz (G =100)
  • HIGH CMR: 106dB
  • WIDE SUPPLY RANGE: ±2.25V to ±18V
  • LOW NONLINEARITY ERROR: 0.001% max
  • INPUT PROTECTION TO ±40V
  • 8-PIN DIP AND SO-8 SURFACE MOUNT
The INA121 is a FET-input, low power instrumentation amplifier offering excellent accuracy. Its versatile three-op amp design and very small size make it ideal for a variety of general purpose applications. Low bias current (±4pA) allows use with high impedance sources.
Gain can be set from 1V to 10,000V/V with a single external resistor. Internal input protection can withstand up to ±40V without damage.
The INA121 is laser-trimmed for very low offset voltage (±200μV), low offset drift (±2μV/°C), and high common-mode rejection (106dB at G = 100). It operates on power supplies as low as ±2.25V (+4.5V), allowing use in battery operated and single 5V systems. Quiescent current is only 450μA.
Package options include 8-pin plastic DIP and SO-8 surface mount. All are specified for the -40°C to +85°C industrial temperature range.
