公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
精密低功耗 G = 10,100 仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 4.5
Input offset (+/-) (Max) (uV) 50
Gain (Min) (V/V) 10
Gain (Max) (V/V) 100
Noise at 1 kHz (Typ) (nV/rt (Hz)) 8
Features Overvoltage Protection
CMRR (Min) (dB) 117
Input offset drift (+/-) (Max) (uV/C) 0.5
Input bias current (+/-) (Max) (nA) 5
Iq (Typ) (mA) 0.75
Bandwidth at min gain (Typ) (MHz) 1
Gain error (+/-) (Max) (%) 0.075
Operating temperature range (C) -40 to 85
Type Fixed Gain
Output swing headroom (to negative supply) (Typ) (V) 0.9
Output swing headroom (to positive supply) (Typ) (V) -0.9
Input common mode headroom (to negative supply) (Typ) (V) 1.7
Input common mode headroom (to positive supply) (Typ) (V) -1.4
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 0.2
Gain non-linearity (+/-) (Max) (%) 0.002
  • LOW OFFSET VOLTAGE: 50μV max
  • LOW DRIFT: 0.5μV/°C max
  • ACCURATE GAIN: ±0.05% at G = 10
  • LOW INPUT BIAS CURRENT: 5nA max
  • HIGH CMR: 117dB min
  • INPUTS PROTECTED to ±40V
  • WIDE SUPPLY RANGE: ±2.25 to ±18V
  • LOW QUIESCENT CURRENT: 750μa
  • 8-PIN PLASTIC DIP, SO-8
The INA141 is a low power, general purpose instrumentation amplifier offering excellent accuracy. Its versatile 3-op amp design and small size make it ideal for a wide range of applications. Current-feedback input circuitry provides wide bandwidth even at high gain (200kHz at G = 100).
Simple pin connections set an accurate gain of 10 or 100V/V without external resistors. Internal input protection can withstand up to ±40V without damage.
The INA141 is laser trimmed for very low offset voltage (50μV), drift (0.5μV/°C) and high common-mode rejection (117dB at G = 100). It operates with power supplies as low as ±2.25V, and quiescent current is only 750μA?ideal for battery operated systems.
The INA141 is available in 8-pin plastic DIP, and SO-8 surface-mount packages, specified for the -40°C to +85°C temperature range.
