公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
高速 FET 输入仪表放大器
Number of channels (#) 1
Vs (Max) (V) 36
Vs (Min) (V) 12
Input offset (+/-) (Max) (uV) 500
Gain (Min) (V/V) 1
Gain (Max) (V/V) 1000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 10
Features Low bias current
CMRR (Min) (dB) 106
Input offset drift (+/-) (Max) (uV/C) 5
Input bias current (+/-) (Max) (nA) 0.02
Iq (Typ) (mA) 3.3
Bandwidth at min gain (Typ) (MHz) 2
Gain error (+/-) (Max) (%) 0.5
Operating temperature range (C) -40 to 85
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 2.3
Output swing headroom (to positive supply) (Typ) (V) -2.3
Input common mode headroom (to negative supply) (Typ) (V) 3
Input common mode headroom (to positive supply) (Typ) (V) -3
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) 1
Gain non-linearity (+/-) (Max) (%) 0.005
  • FET INPUT: IB = 20pA max
  • HIGH SPEED: TS = 4us (G = 100, 0.01%)
  • LOW OFFSET VOLTAGE: 500uV max
  • LOW OFFSET VOLTAGE DRIFT: 5uV/°C max
  • HIGH COMMON-MODE REJECTION: 106dB min
  • 8-PIN PLASTIC DIP, SOL-16 SOIC
  • APPLICATIONS
    • MEDICAL INSTRUMENTATION
    • DATA ACQUISITION
The INA111 is a high speed, FET-input instrumentation amplifier offering excellent performance.
The INA111 uses a current-feedback topology providing extended bandwidth (2MHz at G = 10) and fast settling time (4us to 0.01% at G = 100). A single external resistor sets any gain from 1 to over 1000.
Offset voltage and drift are laser trimmed for excellent DC accuracy. The INA111's FET inputs reduce input bias current to under 20pA, simplifying input filtering and limiting circuitry.
The INA111 is available in 8-pin plastic DIP, and SOL-16 surface-mount packages, specified for the -40°C to +85°C temperature range.
