公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
低噪声、低失真仪表放大器
Number of channels (#) 1
Vs (Max) (V) 50
Vs (Min) (V) 18
Input offset (+/-) (Max) (uV) 250
Gain (Min) (V/V) 1
Gain (Max) (V/V) 1000
Noise at 1 kHz (Typ) (nV/rt (Hz)) 1
Features Current Feedback, Ultra-low noise
CMRR (Min) (dB) 100
Input bias current (+/-) (Max) (nA) 12000
Iq (Typ) (mA) 9
Bandwidth at min gain (Typ) (MHz) 6
Gain error (+/-) (Max) (%) 0.25
Operating temperature range (C) -40 to 85
Type Resistor
Output swing headroom (to negative supply) (Typ) (V) 3
Output swing headroom (to positive supply) (Typ) (V) -3
Input common mode headroom (to negative supply) (Typ) (V) 3
Input common mode headroom (to positive supply) (Typ) (V) -3
Gain non-linearity (+/-) (Max) (%) 0.004
  • LOW NOISE: 1nV/sqrt(Hz)
  • LOW THD+N: 0.0009% at 1kHz, G = 100
  • HIGH GBW: 100MHz at G = 1000
  • WIDE SUPPLY RANGE: ±9V to ±25V
  • HIGH CMRR: >110dB
  • BUILT-IN GAIN SETTING RESISTORS: G = 1, 100
  • UPGRADES AD625
The INA103 is a very low noise, low distortion monolithic instrumentation amplifier. Its current-feedback circuitry achieves very wide bandwidth and excellent dynamic response. It is ideal for low-level audio signals such as balanced low-impedance microphones. The INA103 provides near-theoretical limit noise performance for 200(ohm) source impedances. Many industrial applications also benefit from its low noise and wide bandwidth.
Unique distortion cancellation circuitry reduces distortion to extremely low levels, even in high gain. Its balanced input, low noise and low distortion provide superior performance compared to transformer-coupled microphone amplifiers used in professional audio equipment.
The INA103?s wide supply voltage (±9 to ±25V) and high output current drive allow its use in high-level audio stages as well. A copper lead frame in the plastic DIP assures excellent thermal performance.
The INA103 is available in 16-pin plastic DIP, 16-pin ceramic DIP and SOL-16 surface-mount packages. Commercial and industrial temperature range models are available.
