PGA/VGA | PGA |
Number of channels (#) | 1 |
BW @ Acl (MHz) | 900 |
Vs (Max) (V) | 5 |
Vs (Min) (V) | 4.75 |
Acl, min spec gain (V/V) | 4 |
Gain (Max) (dB) | 13.7 |
Architecture | Fully Differential ADC Driver |
Slew rate (Typ) (V/us) | 3400 |
Operating temperature range (C) | -40 to 85 |
Features | Shutdown, On chip gain resistors |
- 900MHz Bandwidth at Gain of +10dB
- 3300V/μs Slew Rate, VOUT = 2V step
- Adjustable Gain: +10dB to +13.7dB
- IMD3: –100dBc, VOUT = 2VPP, RL = 400Ω,
f = 100MHz - OIP3: 47dBm, f = 100MHz
- Noise Figure: 10.7 dB, f = 100MHz
The THS770012 is a wideband, fully-differential amplifier, with adjustable gain range from +10dB to +13.7dB (with external components). It is designed and optimized specifically for driving 16-bit analog-to-digital converters (ADCs) at input frequencies up to 130MHz, and 14-bit ADCs at input frequencies up to 200MHz. This device provides high bandwidth, high-voltage output with low distortion and low noise, critical in high-speed data acquisition systems that require very high dynamic range, such as wireless base stations and test and measurement applications. This device also makes an excellent differential amplifier for general-purpose, high-speed differential signal chain and short line driver applications.
The THS770012 operates on a nominal +5V single supply, offers very fast, 7.5ns maximum recovery time from overdrive conditions, and has a power-down mode for power saving. The THS770012 is offered in a Pb-free (RoHS compliant) and green, QFN-24 thermally-enhanced package. It is characterized for operation over the industrial temperature range of –40°C to +85°C.
