PGA/VGA | VGA |
Number of channels (#) | 1 |
BW @ Acl (MHz) | 650 |
Vs (Max) (V) | 5.25 |
Vs (Min) (V) | 4.75 |
Acl, min spec gain (V/V) | 0.27 |
Gain (Max) (dB) | 20 |
Architecture | Fully Differential ADC Driver |
Slew rate (Typ) (V/us) | 2900 |
Operating temperature range (C) | -40 to 85 |
Features | Shutdown, Digital Gain Set, Single-ended to Differential conversion |
- Wideband +5-V Operation: 650-MHz Bandwidth
- Low Impedance, Voltage Mode Output
- Wide Gain Range: –11.5 dB to +20 dB
- Precise 0.5-dB Gain Steps
Step-to-Step Gain Error = ±0.03 dB - HD2: –93 dBc at 100 MHz
- HD3: –88 dBc at 100 MHz
- IMD3: –98 dBc at 100 MHz, –95 dBc at 200 MHz
- OIP3: +47 dBm at 100 MHz;
Exceeds +45 dBm for Frequencies to 300 MHz - Flexible Gain Control Interface:
- Supports latched and unlatched options
- Gain may be set in power-down state
- Fast setup and hold times: 2.5 ns
- Low Disable Current: 2 mA
- Pb-Free (RoHS-Compliant) and Green Package
- APPLICATIONS
- Programmable Gain IF Amplifier:
- Differential signal chains
- Single-ended to differential conversion
- Fast Gain Control Loops for:
- Test/measurement
- Digital radio signal chains
- ADC Driver for Wireless Base Station Signal Chains: GSM, WCDMA, MC-GSM
- Radar/Ranging Systems
PowerPAD is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners.
The PGA870 is a wideband programmable-gain amplifier (PGA) for high-speed signal chain and data acquisition systems. The PGA870 has been optimized to provide high bandwidth, low distortion, and low noise, making it ideally suited as a 14-bit analog-to-digital converter (ADC) driver for wireless base station signal chain applications. The wide gain range of –11.5 dB to +20 dB can be adjusted in 0.5-dB gain steps through a 6-bit control word applied to the parallel interface. The gain control interface may be configured as a level-triggered latch or an edge-triggered latch, or it may be placed in an unlatched (transparent) mode. In addition to the 6-bit gain control, the PGA870 contains a power-down pin (PD) that can be used to put the device into a low-current, power-down mode. In this mode, the quiescent current drops to 2 mA, but the gain control circuitry remains active, allowing the gain of the PGA870 to be set before device power-up. The PGA870 is offered in a QFN-28 PowerPAD? package.
