公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
2 通道小型封装的可变增益放大器
PGA/VGA VGA
Number of channels (#) 2
BW @ Acl (MHz) 50
Vs (Max) (V) 5.25
Vs (Min) (V) 4.75
Acl, min spec gain (V/V) 0.32
Gain (Max) (dB) 48
Slew rate (Typ) (V/us) 100
Operating temperature range (C) -40 to 85
Features Shutdown, Analog Gain Set, Digital Gain Set, Integrated Clamps
  • INDEPENDENT CHANNEL CONTROLS:
    • Gain Range: 48dB
    • Clamping Levels
    • Post-Gain: 0, +6dB
  • LOW NOISE: 4.1nV/Hz
  • LOW POWER: 52mW/Channel
  • BANDWIDTH: 50MHz
  • HARMONIC DISTORTION: -53dBc at 5MHz
  • CROSSTALK: -61dB at 5MHz
  • 5V SINGLE SUPPLY
  • POWER-DOWN MODE
  • SMALL QFN-32 PACKAGE (5x5mm)
  • APPLICATIONS
    • MEDICAL AND INDUSTRIAL ULTRASOUND SYSTEMS
      • Suitable for 10-Bit and 12-Bit Systems
    • TEST EQUIPMENT
    • SONAR
All trademarks are the property of their respective owners.
The VCA2617 is a dual-channel, continuously variable, voltage-controlled gain amplifier well-suited for a variety of ultrasound systems as well as applications in proximity detectors and test equipment. The VCA2617 uses a true variable-gain amplifier architecture, achieving very good noise performance at low gains, while not sacrificing high gain distortion performance.
Following a linear-in-dB response, the VCA2617 gain can be varied over a 48dB range with a 0.2V to 2.3V control voltage. Two separate high-impedance control inputs allow for a channel independent variation of the gains. Each channel of the VCA2617 can be configured to provide a gain range of -10dB to 38dB, or -16dB to 32dB, depending on the gain select pin (HG)\. This post-gain feature allows the user to optimize the output swing of VCA2617 for a variety of high-speed analog-to-digital converters (ADC). As a means to improve system overload recovery time, the VCA2617 also provides an internal clamping circuitry where an externally applied voltage sets the desired output clamping level.
The VCA2617 operates on a single +5V supply while consuming only 52mW per channel. It is available in a small QFN-32 package (5x5mm).
