| Common mode voltage (Max) (V) | 80 |
| Common mode voltage (Min) (V) | -16 |
| Input offset (+/-) (Max) (uV) | 2000 |
| Input offset drift (+/-) (Typ) (uV/C) | 2.5 |
| Gain (V/V) | 20 |
| Gain error (%) | 1 |
| Gain error drift (+/-) (Max) (ppm/°C) | 100 |
| CMRR (Min) (dB) | 100 |
| Bandwidth (kHz) | 500 |
| Supply voltage (Max) (V) | 18 |
| Supply voltage (Min) (V) | 2.7 |
| Iq (Max) (mA) | 1.3 |
| Number of channels (#) | 1 |
| Comparators (#) | 0 |
| Features | Low-side Capable |
| Rating | HiRel Enhanced Product |
| Operating temperature range (C) | -55 to 125 |
- Wide Common-Mode Voltage:
–16 V to 80 V - Low Error: 3.0% Over Temp (Max)
- Bandwidth: Up to 500 kHz
- Three Transfer Functions Available: 20 V/V,
50 V/V, and 100 V/V - Complete Current Sense Solution
The INA193A current shunt monitors with voltage output can sense drops across shunts at common-mode voltages from –16 V to 80 V, independent of the INA19x supply voltage. They are available with three output voltage scales: 20 V/V, 50 V/V, and 100 V/V. The 500-kHz bandwidth simplifies use in current control loops.
The INA193A operates from a single 2.7-V to 18-V supply, drawing a maximum of 1300-μA of supply current. It is specified over the extended operating temperature range (–55°C to 125°C), and is offered in a space-saving SOT23 package.
