Common mode voltage (Max) (V) | 36 |
Common mode voltage (Min) (V) | 2.7 |
Input offset (+/-) (Max) (uV) | 2000 |
Input offset drift (+/-) (Typ) (uV/C) | 1 |
Gain (V/V) | Adjustable |
Gain error (%) | 2 |
Gain error drift (+/-) (Max) (ppm/°C) | 100 |
CMRR (Min) (dB) | 100 |
Bandwidth (kHz) | 440 |
Supply voltage (Max) (V) | 40 |
Supply voltage (Min) (V) | 2.7 |
Iq (Max) (mA) | 0.125 |
Number of channels (#) | 1 |
Comparators (#) | 0 |
Features | Current Output |
Rating | Automotive |
Operating temperature range (C) | -40 to 125 |
- Qualified for Automotive Applications
- AEC-Q100 Qualified With the Following Results:
- Device Temperature Grade 1: ?40°C to 125°C
Ambient Operating Temperature Range - Device HBM ESD Classification Level 2
- Device CDM ESD Classification Level C6
- Complete Unidirectional High-Side Current Measurement Circuit
- Wide Supply and Common-Mode Ranges
- INA139-Q1: 2.7 V to 40 V
- INA169-Q1: 2.7 V to 60 V
- Independent Supply and Input Common-Mode
Voltages - Single Resistor Gain Set
- Low Quiescent Current (60 μA Typical)
- Wide Temperature Range: –40°C to +125°C
- Package: TSSOP-8
The INA139-Q1 and INA169-Q1 (INA1x9-Q1) are high-side, unidirectional, current shunt monitors. Wide input common-mode voltage range, high-speed, low quiescent current, and TSSOP-8 packaging enable use in a variety of applications.
The device converts a differential input voltage to a current output. This current is converted back to a voltage with an external load resistor that sets any gain from 1 to over 100. Although designed for current shunt measurement, the circuit invites creative applications in measurement and level shifting.
Both the INA139-Q1 and INA169-Q1 are available in a TSSOP-8 package, and are specified for the –40°C to +125°C temperature range.
