公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  185粉丝
--- 产品详情 ---
2.7V 至 60V、双向、400kHz 可变增益电流感应放大器
Common mode voltage (Max) (V) 60
Common mode voltage (Min) (V) 2.7
Input offset (+/-) (Max) (uV) 1000
Input offset drift (+/-) (Typ) (uV/C) 1
Gain (V/V) Adjustable
Gain error (%) 2
Gain error drift (+/-) (Max) (ppm/°C) 100
CMRR (Min) (dB) 100
Bandwidth (kHz) 400
Supply voltage (Max) (V) 60
Supply voltage (Min) (V) 2.7
Iq (Max) (mA) 0.125
Number of channels (#) 1
Comparators (#) 0
Features Bi-directional, Current Output
Rating Catalog
Operating temperature range (C) -40 to 85
  • COMPLETE BIDIRECTIONAL CURRENT MEASUREMENT CIRCUIT
  • WIDE SUPPLY RANGE: 2.7V to 40V
  • SUPPLY-INDEPENDENT COMMON-MODE VOLTAGE: 2.7V TO 60V
  • RESISTOR PROGRAMMABLE GAIN SET
  • LOW QUIESCENT CURRENT: 75μA (typ)
  • MSOP-8 PACKAGE
  • APPLICATIONS
    • CURRENT SHUNT MEASUREMENT:
        Automotive, Telephone, Computers, Power Systems, Test, General Instrumentation
    • PORTABLE AND BATTERY-BACKUP SYSTEMS
    • BATTERY CHARGERS
    • POWER MANAGEMENT
    • CELL PHONES
All trademarks are the property of their respective owners.
The INA170 is a high-side, bidirectional current shunt monitor featuring a wide input common-mode voltage range, low quiescent current, and a tiny MSOP-8 package.
Bidirectional current measurement is accomplished by output offsetting. The offset voltage level is set with an external resistor and voltage reference. This permits measurement of a bidirectional shunt current while using a single supply for the INA170.
Input common-mode and power-supply voltages are independent. Input voltage can range from +2.7V to +60V on any supply voltage from +2.7V to +40V. Low 10μA input bias current adds minimal error to the shunt current.
The INA170 converts a differential input voltage to a current output. This current develops a voltage across an external load resistor, setting any gain from 1 to over 100.
The INA170 is available in an MSOP-8 package, and is specified over the extended industrial temperature range, ?40°C to +85°C with operation from ?55°C to +125°C.
