公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
双通道低失真高速轨到轨输出运算放大器
Architecture Voltage FB
Number of channels (#) 2
Total supply voltage (Min) (+5V=5, +/-5V=10) 2.7
Total supply voltage (Max) (+5V=5, +/-5V=10) 16
GBW (Typ) (MHz) 120
BW @ Acl (MHz) 170
Acl, min spec gain (V/V) 1
Slew rate (Typ) (V/us) 750
Vn at flatband (Typ) (nV/rtHz) 13
Vn at 1 kHz (Typ) (nV/rtHz) 13
Iq per channel (Typ) (mA) 12
Vos (offset voltage @ 25 C) (Max) (mV) 25
Rail-to-rail Out
Rating Catalog
Operating temperature range (C) -40 to 85
CMRR (Typ) (dB) 96
Input bias current (Max) (pA) 3000000
Offset drift (Typ) (uV/C) 0
Output current (Typ) (mA) 100
2nd harmonic (dBc) 78
3rd harmonic (dBc) 85
Frequency of harmonic distortion measurement (MHz) 5
  • High Speed
    • 100 MHz Bandwidth (-3 dB, G = 2)
    • 900 V/μs Slew Rate
  • Excellent Video Performance
    • 50 MHz Bandwidth (0.1 dB, G = 2)
    • 0.007% Differential Gain
    • 0.007° Differential Phase
  • Rail-to-Rail Output Swing
    • VO = -4.5 / 4.5 (RL= 150 Ω)
  • High Output Drive, IO = 100 mA (typ)
  • Ultralow Distortion
    • HD2 = -78 dBc (f = 5 MHz, RL = 150 Ω)
    • HD3 = -85 dBc (f = 5 MHz, RL = 150 Ω)
  • Wide Range of Power Supplies
    • VS = 3 V to 15 V
  • APPLICATIONS
    • Video Line Driver
    • Imaging
    • DVD / CD ROM
    • Active Filtering
    • General Purpose Signal Chain Conditioning
The SN1050x family is a set of rail-to-rail output single,dual, and triple low-voltage, high-output swing, low-distortion high-speed amplifiers ideal for driving data converters, video switching, or low distortion applications. This family of voltage-feedback amplifiers can operate from a single 15-V power supply down to a single 3-V power supply while consuming only 14 mA of quiescent current per channel. In addition, the family offers excellent ac performance with 100-MHz bandwidth, 900-V/μs slew rate and harmonic distortion (THD) at -78 dBc at 5 MHz.
