公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
低功耗单电源差分放大器
Number of channels (#) 1
Vs (Min) (V) 2.7
Vs (Max) (V) 36
CMRR (Min) (dB) 76
Common mode input low (Min) (V) -15
Common mode input high (Max) (V) 28
Input offset (+/-) (Max) (uV) 250
Iq (Typ) (mA) 0.16
Small signal bandwidth (Typ) (MHz) 0.3
Slew rate (Typ) (V/us) 0.1
Gain (Min) (V/V) 1
Gain (Max) (V/V) 1
Gain error (+/-) (Max) (%) 0.075
Rating Catalog
Operating temperature range (C) -40 to 85
Gain drift (Max) (ppm/C) 1
  • LOW QUIESCENT CURRENT: 160mA
  • WIDE SUPPLY RANGE
    • Single Supply: 2.7V to 36V
    • Dual Supplies: ±1.35V to ±18V
  • LOW GAIN ERROR: ±0.075% max
  • LOW NONLINEARITY: 0.001% max
  • HIGH CMR: 90dB
  • HIGHLY VERSATILE CIRCUIT
  • EASY TO USE
  • LOW COST
  • 8-PIN DIP AND SO-8 PACKAGES
The INA132 is a low power, unity-gain differential amplifier consisting of a precision op amp with a precision resistor network. The on-chip resistors are laser trimmed for accurate gain and high commonmode rejection. Excellent TCR tracking of the resistors maintains gain accuracy and common-mode rejection over temperature. The internal op amp’s common-mode range extends to the negative supply—ideal for single-supply applications. It operates on single (2.7V to 36V) or dual supplies (±1.35V to ±18V).
The differential amplifier is the foundation of many commonly used circuits. The INA132 provides this circuit function without using an expensive precision resistor network. The INA132 is available in 8-pin DIP and SO-8 surface-mount packages and is specified for operation over the extended industrial temperature range, ?40°C to +85°C.
