| Number of channels (#) | 1 |
| Vs (Min) (V) | 10 |
| Vs (Max) (V) | 36 |
| CMRR (Min) (dB) | 86 |
| Common mode input low (Min) (V) | -200 |
| Common mode input high (Max) (V) | 200 |
| Input offset (+/-) (Max) (uV) | 1000 |
| Iq (Typ) (mA) | 2 |
| Small signal bandwidth (Typ) (MHz) | 0.2 |
| Slew rate (Typ) (V/us) | 2.6 |
| Gain (Min) (V/V) | 1 |
| Gain (Max) (V/V) | 1 |
| Gain error (+/-) (Max) (%) | 0.05 |
| Rating | Catalog |
| Operating temperature range (C) | -40 to 85 |
| Gain drift (Max) (ppm/C) | 10 |
- COMMON-MODE INPUT RANGE:
±200V (VS = ±15V) - PROTECTED INPUTS:
±500V Common-Mode
±500V Differential - UNITY GAIN: 0.02% Gain Error max
- NONLINEARITY: 0.001% max
- CMRR: 86dB min
- APPLICATIONS
- CURRENT MONITOR
- BATTERY CELL-VOLTAGE MONITOR
- GROUND BREAKER
- INPUT PROTECTION
- SIGNAL ACQUISITION IN NOISY ENVIRONMENTS
- FACTORY AUTOMATION
The INA117 is a precision unity-gain difference amplifier with very high common-mode input voltage range. It is a single monolithic IC consisting of a precision op amp and integrated thin-film resistor network. It can accurately measure small differential voltages in the presence of common-mode signals up to ±200V. The INA117 inputs are protected from momentary common-mode or differential overloads up to ±500V.
In many applications, where galvanic isolation is not essential, the INA117 can replace isolation amplifiers. This can eliminate costly isolated input-side power supplies and their associated ripple, noise and quiescent current. The INA117\x92s 0.001% nonlinearity and 200kHz bandwidth are superior to those of conventional isolation amplifiers.
The INA117 is available in 8-pin plastic mini-DIP and SO-8 surface-mount packages, specified for the \x9640°C to +85°C temperature range. The metal TO-99 models are available specified for the \x9640°C to +85°C and \x9655°C to +125°C temperature range.
