公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
精确固定增益差分放大器
Number of channels (#) 1
Vs (Min) (V) 10
Vs (Max) (V) 36
CMRR (Min) (dB) 86
Common mode input low (Min) (V) -11
Common mode input high (Max) (V) 11
Input offset (+/-) (Max) (uV) 200
Iq (Typ) (mA) 1.5
Small signal bandwidth (Typ) (MHz) 5
Slew rate (Typ) (V/us) 3
Gain (Min) (V/V) 10
Gain (Max) (V/V) 10
Gain error (+/-) (Max) (%) 0.025
Rating Catalog
Operating temperature range (C) -40 to 85
Gain drift (Max) (ppm/C) 4
  • ACCURATE GAIN: ±0.025% max
  • HIGH COMMON-MODE REJECTION: 86dB min
  • NONLINEARITY: 0.001% max
  • EASY TO USE
  • PLASTIC 8-PIN DIP, SO-8 SOIC PACKAGES
  • applications
    • G = 10 DIFFERENTIAL AMPLIFIER
    • G = +10 AMPLIFIER
    • G = -10 AMPLIFIER
    • G = +11 AMPLIFIER
    • INSTRUMENTATION AMPLIFIER
All trademarks are the property of their respective owners.
The INA106 is a monolithic Gain = 10 differential amplifier consisting of a precision op amp and on-chip metal film resistors. The resistors are laser trimmed for accurate gain and high common-mode rejection. Excellent TCR tracking of the resistors maintains gain accuracy and common-mode rejection over temperature.
The differential amplifier is the foundation of many commonly used circuits. The INA106 provides this precision circuit function without using an expensive resistor network. The INA106 is available in 8-pin plastic DIP and SO-8 surface-mount packages.
