公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有 I2C 控制的立体声数字音频延迟处理器
Audio delay per channel (ms) 170
Operating temperature range (C) -40 to 85
Rating Catalog
  • Digital Audio Formats: 16-24-bit I2S, Right-Justified, Left-Justified
  • I2C Bus Controlled
  • Single Serial Input Port
  • Delay Time: 170 ms/ch at fs = 48 kHz
  • Delay Resolution: One Sample
  • Delay Memory Cleared on Power-Up or After Delay Changes
    • Eliminates Erroneous Data From Being Output
  • 3.3 V Operation With 5 V Tolerant I/O and I2C Control
  • Supports Audio Bit Clock Rates of 32 to 64 fs with fs = 32 kHz-192 kHz
  • No external crystal or oscillator required
    • All Internal Clocks Generated From the Audio Clock
  • Surface Mount 4mm × 4mm, 16-pin QFN Package
  • APPLICATIONS
    • High Definition TV Lip-Sync Delay
    • Flat Panel TV Lip-Sync Delay
    • Home Theater Rear-Channel Effects
    • Wireless Speaker Front-Channel Synchronization
The TPA5050 accepts a single serial audio input, buffers the data for a selectable period of time, and outputs the delayed audio data on a single serial output. One device allows delay of up to 170 ms/ch (fs = 48 kHz) to synchronize the audio stream to the video stream in systems with complex video processing algorithms. If more delay is needed, the devices can be connected in series.
