公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有集成平衡-非平衡变压器的 2.3-2.9GHz 差分至单端低功耗放大器
Current consumption (mA) 106
Frequency (Min) (MHz) 2300
Frequency (Max) (MHz) 2900
Gain (Typ) (dB) 18
Impedance match (Ohms) 50
Noise figure (Typ) (dB) 3.2
Number of channels (#) 1
Operating temperature range (C) -40 to 105
Output enable Yes
Output IP3 (Typ) (dBm) 33
P1dB (Typ) (dBm) 18
Type Active Balun
Rating Catalog
Power down current 10 mA
  • Single-Channel, Differential Input to Single-Ended Output RF Gain Block Amplifier
  • 18-dB Typical Gain Across the Band
  • 3.5-dB Noise Figure
  • 35-dBm OIP3
  • 18-dBm Output P1dB
  • 375-mW Power Consumption on 3.3-V Single Supply
  • Up to 105°C TC Operating Temperature
The LMH9126 is high-performance, single-channel, differential input to single-ended output transmit RF gain block amplifier supporting 2.6-GHz center frequency band. The device is well suited to support requirements for the next generation 5G AAS or small cell applications while driving the input of a power amplifier (PA). The RF amplifier provides 18-dB typical gain with good linearity performance of 35-dBm output IP3, while maintaining less than 4-dB noise figure across the whole 1-dB bandwidth. The device is internally matched for 100-Ω differential input impedance providing easy interface with an RF-sampling or Zero-IF analog front-end (AFE) at the input. Also, the device is internally matched for 50-Ω single-ended output impedance required for easy interface with a post-amplifier, SAW filter, or PA.
Operating on a single 3.3-V supply, the device consumes only 375 mW of active power making it suitable for high-density 5G massive MIMO applications. Also, the device is available in a space saving 2-mm × 2-mm, 12-pin QFN package. The device is rated for an operating temperature of up to 105°C to provide a robust system design. There is a 1.8-V JEDEC compliant power down pin available for fast power down and power up of the device suitable for time division duplex (TDD) systems.
