公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
2 通道、50MHz、高保真、高性能、全差动音频运算放大器
Number of channels (#) 1
Total supply voltage (Min) (+5V=5, +/-5V=10) 5
Total supply voltage (Max) (+5V=5, +/-5V=10) 36
GBW (Typ) (MHz) 50
Slew rate (Typ) (V/us) 18
Rail-to-rail No
Vos (offset voltage @ 25 C) (Max) (mV) 1
Iq per channel (Typ) (mA) 10
Vn at 1 kHz (Typ) (nV/rtHz) 2.1
Features Shutdown
THD + N @ 1 kHz (Typ) (%) 0.00003
Rating Catalog
Operating temperature range (C) -40 to 85
Output current (Typ) (mA) 80
Architecture Voltage FB
CMRR (Typ) (dB) 102
Input bias current (Max) (pA) 200000
  • Drives 600? Loads with Full Output Signal Swing
  • Optimized for Superior Audio Signal Fidelity
  • Output Short Circuit Protection
  • PSRR and CMRR Exceed 100dB (typ)
  • Available in SO PowerPad Package
All trademarks are the property of their respective owners.
The LME49724 is an ultra-low distortion, low noise, high slew rate fully-differential operational amplifier optimized and fully specified for high performance, high fidelity applications. Combining advanced leading-edge process technology with state of the art circuit design, the LME49724 fully-differential audio operational amplifier delivers superior audio signal amplification for outstanding audio performance. The LME49724 combines extremely low voltage noise density (2.1nV/√Hz) with vanishingly low THD+N (0.00003%) to easily satisfy the most demanding audio applications. To ensure that the most challenging loads are driven without compromise, the LME49724 has a high slew rate of ±18V/μs and an output current capability of ±80mA. Further, dynamic range is maximized by an output stage that drives 600? loads to 52VP-P while operating on a ±15V supply voltage.
The LME49724's outstanding CMRR (102dB), PSRR (125dB), and VOS (0.2mV) results in excellent operational amplifier DC performance.
The LME49724 has a wide supply range of ±2.5V to ±18V. Over this supply range the LME49724’s input circuitry maintains excellent common-mode and power supply rejection, as well as maintaining its low input bias current. The LME49724 is unity gain stable. This Fully-Differential Audio Operational Amplifier achieves outstanding AC performance while driving complex loads with capacitive values as high as 100pF.
