公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
2 通道、20MHz、RRIO、高保真、高性能音频运算放大器
Number of channels (#) 2
Total supply voltage (Min) (+5V=5, +/-5V=10) 2.2
Total supply voltage (Max) (+5V=5, +/-5V=10) 5.5
GBW (Typ) (MHz) 20
Slew rate (Typ) (V/us) 8.5
Rail-to-rail In, Out
Vos (offset voltage @ 25 C) (Max) (mV) 1.5
Iq per channel (Typ) (mA) 2.15
Vn at 1 kHz (Typ) (nV/rtHz) 4
Features Premium Sound, Shutdown
THD + N @ 1 kHz (Typ) (%) 0.0002
Rating Catalog
Operating temperature range (C) -40 to 85
Output current (Typ) (mA) 100
Architecture Voltage FB
CMRR (Typ) (dB) 93
Input bias current (Max) (pA) 1
  • Rail-to-Rail Input and Output
  • Easily Drives 10k? Loads to Within 10mV of Each Power Supply Voltage
  • Optimized for Superior Audio Signal Fidelity
  • Output Short Circuit Protection
Key Specifications
  • Power Supply Voltage Range: 2.2V to 5.5V
  • Quiescent Current: 2.15mA (typ)
  • THD+N (AV = 2, VOUT = 4Vp-p, f IN = 1kHz)
    • RL = 2k?: 0.00008% (typ)
    • RL = 600?: 0.0001% (typ)
  • Input Noise Density: 4nV/√Hz (typ), @ 1kHz
  • Slew Rate: ±8.5V/μs (typ)
  • Gain Bandwidth Product: 20MHz (typ)
  • Open Loop Gain (RL = 600?): 118dB (typ)
  • Input Bias Current: 40fA (typ)
  • Input Offset Voltage: 0.3mV (typ)
  • PSRR: 103dB (typ)
All trademarks are the property of their respective owners.
The LME49721 is a low-distortion, low-noise Rail-to-Rail Input/Output operational amplifier optimized and fully specified for high-performance, high-fidelity applications. Combining advanced leading-edge process technology with state-of-the-art circuit design, the LME49721 Rail-to-Rail Input/Output operational amplifier delivers superior signal amplification for outstanding performance. The LME49721 combines a very high slew rate with low THD+N to easily satisfy demanding applications. To ensure that the most challenging loads are driven without compromise, the LME49721 has a high slew rate of ±8.5V/μs and an output current capability of ±9.7mA. Further, dynamic range is maximized by an output stage that drives 10k? loads to within 10mV of either power supply voltage.
The LME49721 has a wide supply range of 2.2V to 5.5V. Over this supply range the LME49721’s input circuitry maintains excellent common-mode and power supply rejection, as well as maintaining its low input bias current. The LME49721 is unity gain stable.
