Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.2 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.025 |
GBW (Typ) (MHz) | 5.5 |
Features | EMI Hardened, Small Size, e-Trim? |
Slew rate (Typ) (V/us) | 2 |
Rail-to-rail | In, Out |
Offset drift (Typ) (uV/C) | 0.32 |
Iq per channel (Typ) (mA) | 0.76 |
Vn at 1 kHz (Typ) (nV/rtHz) | 7.5 |
CMRR (Typ) (dB) | 90 |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
Input bias current (Max) (pA) | 10 |
Output current (Typ) (mA) | 30 |
Architecture | CMOS |
THD + N @ 1 kHz (Typ) (%) | 0.00027 |
- Low Noise: 7.5 nV/√Hz at 1 kHz
- 0.1 Hz to 10 Hz Noise: 0.8 μVPP
- Quiescent Current: 760 μA (typical)
- Low Offset Voltage: 5 μV (typ)
- Gain Bandwidth Product: 5.5 MHz
- Rail-to-Rail Input and Output
- Single-Supply Operation
- Supply Voltage: 2.2 V to 5.5 V
- Space-Saving Packages:
- SC70, SOT-23, DSBGA, VSSOP, TSSOP
The OPA376 family represents a new generation of low-noise operational amplifiers with e-trim?, offering outstanding dc precision and ac performance. Rail-to-rail input and output, low offset (25 μV, maximum), low noise (7.5 nV/√Hz), quiescent current of 950 μA (maximum), and a 5.5-MHz bandwidth make this part very attractive for a variety of precision and portable applications. In addition, this device has a reasonably wide supply range with excellent PSRR, making it attractive for applications that run directly from batteries without regulation.
The OPA376 (single version) is available in MicroSIZE SC70-5, SOT-23-5, and SOIC-8 packages. The OPA2376 (dual) is offered in the DSBGA-8, VSSOP-8, and SOIC-8 packages. The OPA4376 (quad) is offered in a TSSOP-14 package. All versions are specified for operation from –40°C to +125°C.
