公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
单通道、110MHz、高保真、高电流耳机缓冲器
Number of channels (#) 1
Total supply voltage (Min) (+5V=5, +/-5V=10) 4.5
Total supply voltage (Max) (+5V=5, +/-5V=10) 36
GBW (Typ) (MHz) 180
Slew rate (Typ) (V/us) 2000
Rail-to-rail No
Vos (offset voltage @ 25 C) (Max) (mV) 60
Iq per channel (Typ) (mA) 14
Vn at 1 kHz (Typ) (nV/rtHz) 3
THD + N @ 1 kHz (Typ) (%) 0.00003
Rating Catalog
Operating temperature range (C) -40 to 85
Output current (Typ) (mA) 250
Architecture Voltage FB
CMRR (Typ) (dB) 0
Input bias current (Max) (pA) 5000000
  • Pin-Selectable Bandwidth and Quiescent Current
  • Pure Fidelity, Pure Performance
  • Short Circuit Protection
  • Thermal Shutdown
  • TO–263 Surface-Mount Package
Key Specifications
  • Low THD+N (VOUT = 3VRMS, f = 1kHz, ): 0.00003% (typ)
  • Slew Rate: 2000V/μs (typ)
  • High Output Current: 250mA (typ)
  • Bandwidth
    • ?BW Pin Floating: 110MHz (typ)
    • ?BW Connected to VEE: 180MHz (typ)
  • Supply Voltage Range: ±2.25V ≤ VS ≤ ±18V
All trademarks are the property of their respective owners.
The LME49600 is a high performance, low distortion high fidelity 250mA audio buffer. The LME49600 is designed for a wide range of applications. It can be used inside the feedback loop of op amps.
The LME49600 offers a pin-selectable bandwidth: a low current, 110MHz bandwidth mode that consumes 7.3mA and a wide 180MHz bandwidth mode that consumes 13.2mA. In both modes the LME49600 has a nominal 2000V/μs slew rate. Bandwidth is easily adjusted by either leaving the BW pin unconnected or connecting a resistor between the BW pin and the VEE pin.
The LME49600 is fully protected through internal current limit and thermal shutdown.
