公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有单端输出的 25W 立体声、10V 至 30V 电源电压、模拟输入 D 类音频放大器
Audio input type Analog Input
Architecture Class-D
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 30
Power stage supply (Min) (V) 10
Load (Min) (ohms) 4
Output power (W) 25
SNR (dB) 99
THD + N @ 1 kHz (%) 0.08
Iq (Typ) (mA) 23
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 10
Analog supply (Max) (V) 30
PSRR (dB) 60
Operating temperature range (C) -40 to 85
  • 25-W/ch into a 4- Load from a 27-V Supply
  • 20-W/ch into a 4- Load from a 24-V Supply
  • Operates from 10 V to 30 V
  • Efficient Class-D Operation Eliminates Need for Heat Sinks
  • Four Selectable, Fixed-Gain Settings
  • Internal Oscillator (No External Components Required)
  • Single-Ended Analog Inputs
  • Thermal and Short-Circuit Protection With Auto Recovery
  • Space-Saving Surface-Mount 24-Pin TSSOP Package
  • Pin-to-Pin compatible with TPA3120D2
  • Advanced Power-Off Pop Reduction
  • APPLICATIONS
    • Televisions
System Two, Audio Precision are trademarks of Audio Precision, Inc.
The TPA3123D2 is a 25-W (per channel) efficient, Class-D audio power amplifier for driving stereo speakers in a single-ended configuration or a mono speaker in a bridge-tied-load configuration. The TPA3123D2 can drive stereo speakers as low as 4?. The efficiency of the TPA3123D2 eliminates the need for an external heat sink when playing music.
The gain of the amplifier is controlled by two gain select pins. The gain selections are 20, 26, 32, 36?dB.
The patented start-up and shut-down sequences minimize pop noise in the speakers without additional circuitry.
