公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
精密 (0.025mV)、低噪声 (7.5nV/rtHz)、低静态电流 (760uA) 运算放大器
Number of channels (#) 1
Total supply voltage (Max) (+5V=5, +/-5V=10) 5.5
Total supply voltage (Min) (+5V=5, +/-5V=10) 2.2
Vos (offset voltage @ 25 C) (Max) (mV) 0.025
GBW (Typ) (MHz) 5.5
Features EMI Hardened, Small Size, e-Trim?
Slew rate (Typ) (V/us) 2
Rail-to-rail In, Out
Offset drift (Typ) (uV/C) 0.32
Iq per channel (Typ) (mA) 0.76
Vn at 1 kHz (Typ) (nV/rtHz) 7.5
CMRR (Typ) (dB) 90
Rating Catalog
Operating temperature range (C) -40 to 125
Input bias current (Max) (pA) 10
Output current (Typ) (mA) 30
Architecture CMOS
THD + N @ 1 kHz (Typ) (%) 0.00027
  • Low Noise: 7.5 nV/√Hz at 1 kHz
  • 0.1 Hz to 10 Hz Noise: 0.8 μVPP
  • Quiescent Current: 760 μA (typical)
  • Low Offset Voltage: 5 μV (typ)
  • Gain Bandwidth Product: 5.5 MHz
  • Rail-to-Rail Input and Output
  • Single-Supply Operation
  • Supply Voltage: 2.2 V to 5.5 V
  • Space-Saving Packages:
    • SC70, SOT-23, DSBGA, VSSOP, TSSOP
The OPA376 family represents a new generation of low-noise operational amplifiers with e-trim?, offering outstanding dc precision and ac performance. Rail-to-rail input and output, low offset (25 μV, maximum), low noise (7.5 nV/√Hz), quiescent current of 950 μA (maximum), and a 5.5-MHz bandwidth make this part very attractive for a variety of precision and portable applications. In addition, this device has a reasonably wide supply range with excellent PSRR, making it attractive for applications that run directly from batteries without regulation.
The OPA376 (single version) is available in MicroSIZE SC70-5, SOT-23-5, and SOIC-8 packages. The OPA2376 (dual) is offered in the DSBGA-8, VSSOP-8, and SOIC-8 packages. The OPA4376 (quad) is offered in a TSSOP-14 package. All versions are specified for operation from –40°C to +125°C.
