公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 87mW 耳机放大器和 3D 增强功能的 2.2W 单声道、模拟输入 D 类放大器
Audio input type Analog Input
Architecture Class-D
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 8
Output power (W) 1.19
THD + N @ 1 kHz (%) 0.03
Iq (Typ) (mA) 4.5
Control interface I2C
Closed/open loop Open
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 5.5
PSRR (dB) 79
Operating temperature range (C) -40 to 85
  • I2C Control Interface
  • I2C Programmable Texas Instruments 3D Audio
  • I2C Controlled 32 Step Digital Volume Control (-59.5dB to +18dB)
  • Three Independent Volume Channels (Left, Right, Mono)
  • Eight Distinct Output Modes
  • Small, 25–Bump DSBGA Packaging
  • “Click and Pop” Suppression Circuitry
  • Thermal Shutdown Protection
  • Low Shutdown Current (0.1μA, typ)
  • RF Suppression
  • Differential Mono and Stereo Inputs
  • Stereo Input Mux
Key Specifications
  • THD+N at 1kHz, 500mW?into 8? BTL (3.3V): 1.0% (typ)
  • THD+N at 1kHz, 37mW?into 32? SE (3.3V): 1.0% (typ)
  • Single Supply Operation (VDD): 2.7 to 5.5 V
  • I2C Single Supply Operation: 2.2 to 5.5 V
All trademarks are the property of their respective owners.
The LM4947 is an audio subsystem capable of efficiently delivering 500mW (Class D operation) of continuous average power into a mono 8? bridged-tied load (BTL) with 1% THD+N, 37mW (Class AB operation) power channel of continuous average power into stereo 32? single-ended (SE) loads with 1% THD+N, or an output capacitor-less (OCL) configuration with identical specification as the SE configuration, from a 3.3V power supply.
The LM4947 has six input channels: one pair for a two-channel stereo signal, the second pair for a secondary two-channel stereo input, and the third pair for a differential single-channel mono input. Additionally, the two sets of stereo inputs may be configured as a single stereo differential input (differential left and differential right). The LM4947 features a 32-step digital volume control and eight distinct output modes. The digital volume control, 3D enhancement, and output modes are programmed through a two-wire I2C compatible interface that allows flexibility in routing and mixing audio channels.
The RF suppression circuitry in the LM4947 makes it well-suited for GSM mobile phones and other portable applications in which strong RF signals generated by an antenna (and long output traces) may couple audibly into the amplifier.
The LM4947 is designed for cellular phones, PDAs, and other portable handheld applications. It delivers high quality output power from a surface-mount package and requires only eight external components in the OCL mode (two additional components in SE mode).
