公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
免滤波 2.5 立体声 D 类音频功率放大器
Audio input type Analog Input
Architecture Class-D
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 2.4
Power stage supply (Min) (V) 5.5
Load (Min) (ohms) 4
Output power (W) 2.5
SNR (dB) 96
THD + N @ 1 kHz (%) 0.07
Iq (Typ) (mA) 5
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 2.4
Analog supply (Max) (V) 5.5
PSRR (dB) 75
Operating temperature range (C) -40 to 85
  • Output Short Circuit Protection
  • Stereo Class D Operation
  • No Output Filter Required
  • Logic Selectable Gain
  • Independent Shutdown Control
  • Minimum External Components
  • Click and Pop Suppression
  • Micro-Power Shutdown
  • Available in Space-Saving 2mm x 2mm x 0.6mm DSBGA, and 4mm x 4mm x 0.8mm WQFN Packages
Key Specifications
  • Efficiency at 3.6V, 100mW into 8?: 80% (typ)
  • Efficiency at 3.6V, 500mW into 8?: 85% (typ)
  • Efficiency at 5V, 1W into 8?: 85% (typ)
  • Quiescent Power Supply Current
    ? at 3.6V supply: 4mA
  • Power Output at VDD = 5V,
    ? RL = 4?, THD ≤ 10%: 2.5 W (typ)
  • Shutdown Current: 0.03μA (typ)
All trademarks are the property of their respective owners.
The LM4674 is a single supply, high efficiency, 2.5W/channel, filterless switching audio amplifier. A low noise PWM architecture eliminates the output filter, reducing external component count, board area consumption, system cost, and simplifying design.
The LM4674 is designed to meet the demands of mobile phones and other portable communication devices. Operating from a single 5V supply, the device is capable of delivering 2.5W/channel of continuous output power to a 4? load with less than 10% THD+N. Flexible power supply requirements allow operation from 2.4V to 5.5V.
The LM4674 features high efficiency compared to conventional Class AB amplifiers. When driving an 8? speaker from a 3.6V supply, the device features 85% efficiency at PO = 500mW. Four gain options are pin selectable through the G0 and G1 pins.
Output short circuit protection prevents the device from being damaged during fault conditions. Superior click and pop suppression eliminates audible transients on power-up/down and during shutdown. Independent left/right shutdown control maximizes power savings in mixed mono/stereo applications.
