公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
2.65W 单声道、模拟输入 D 类扬声器放大器
Audio input type Analog Input
Architecture Class-D
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.4
Load (Min) (ohms) 4
Output power (W) 2.65
SNR (dB) 97
THD + N @ 1 kHz (%) 0.03
Iq (Typ) (mA) 2.6
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 2.4
Analog supply (Max) (V) 5.5
PSRR (dB) 78
Operating temperature range (C) -40 to 85
  • Mono Class D Operation
  • No Output Filter Required for Inductive Loads
  • Externally Configurable Gain
  • Very Fast Turn On Time: 17μs (typ)
  • Minimum External Components
  • "Click and Pop" Suppression Circuitry
  • Micro-Power Shutdown Mode
  • Available in Space-Saving 0.4mm Pitch DSBGA and WSON Packages
Key Specifications
  • Efficiency at 3.6V, 400mW into 8? Speaker 88% (typ)
  • Efficiency at 3.6V, 100mW into 8? Speaker 80% (typ)
  • Efficiency at 5V, 1W into 8? Speaker 86% (typ)
  • Quiescent Current, 3.6V Supply 2.1mA (typ)
  • Total Shutdown Power Supply Current
    0.01μA (typ)
  • Single Supply Range 2.4V to 5.5V
  • PSRR, f = 217Hz 78dB
All trademarks are the property of their respective owners.
The LM4673 is a single supply, high efficiency, 2.65W, mono, Class D audio amplifier. A low noise, filterless PWM architecture eliminates the output filter, reducing external component count, board area consumption, system cost, and simplifying design.
The LM4673 is designed to meet the demands of mobile phones and other portable communication devices. Operating on a single 5V supply, it is capable of driving a 4? speaker load at a continuous average output of 2.1W with less than 1% THD+N. Its flexible power supply requirements allow operation from 2.4V to 5.5V.
The LM4673 has high efficiency with speaker loads compared to a typical Class AB amplifier. With a 3.6V supply driving an 8? speaker, the IC's efficiency for a 100mW power level is 80%, reaching 88% at 400mW output power.
The LM4673 features a low-power consumption shutdown mode. Shutdown may be enabled by driving the Shutdown pin to a logic low (GND).
The gain of the LM4673 is externally configurable which allows independent gain control from multiple sources by summing the signals. Output short circuit and thermal overload protection prevent the device from damage during fault conditions.
