公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有直流音量控制和立体声耳机驱动器的 2W、立体声、AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 4
Load (Min) (ohms) 4
Output power (W) 2
THD + N @ 1 kHz (%) 0.8
Iq (Typ) (mA) 5
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 4
Analog supply (Max) (V) 5.5
PSRR (dB) 70
Operating temperature range (C) -40 to 85
  • 2 W Into 4- Speakers With External Heatsink
  • DC Volume Control With 2-dB
    Steps from -40 dB to 20 dB
    • Fade Mode
    • -85-dB Mute Mode
  • Differential Inputs
  • 1-μA Shutdown Current (Typical)
  • Headphone Mode
  • APPLICATIONS
    • LCD Monitors
The TPA6021A4 is a stereo audio power amplifier that drives 2 W/channel of continuous RMS power into a 4- load when utilizing a heat sink. Advanced dc volume control minimizes external components and allows BTL (speaker) volume control and SE (headphone) volume control.
The 20-pin DIP package allows for the use of a heatsink which provides higher output power.
To ensure a smooth transition between active and shutdown modes, a fade mode ramps the volume up and down.
