Audio input type | Analog Input |
Architecture | Class-AB |
Speaker channels (Max) | Stereo |
Power stage supply (Max) (V) | 5.5 |
Power stage supply (Min) (V) | 2.7 |
Load (Min) (ohms) | 3 |
Output power (W) | 2.2 |
THD + N @ 1 kHz (%) | 0.05 |
Iq (Typ) (mA) | 11 |
Control interface | GPIO |
Closed/open loop | Open |
Analog supply (Min) (V) | 2.7 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 78 |
Operating temperature range (C) | -20 to 85 |
- Improved Click and Pop Circuitry Virtually Eliminates Noise During Turn On/Off Transitions
- DC Volume Control Interface
- System Beep Detect
- Stereo Switchable Bridged/Single-Ended Power Amplifiers
- Selectable Internal/External Gain and Bass Boost
- Thermal Shutdown Protection Circuitry
- Unity Gain Stable
Key Specifications
- PO at 1% THD+N
- into 3Ω: 2.2W (typ)
- into 4Ω: 2.0W (typ)
- into 8Ω: 1.3W (typ)
- Single-ended mode
- THD+N at 92mW into 32Ω: 1.0% (typ)
- Shutdown Current: 0.5μA (typ)
All trademarks are the property of their respective owners.
The LM4938 is a monolithic integrated circuit that provides DC volume control, and stereo bridged audio power amplifiers capable of producing 2W into 4? with less than 1.0% THD or 2.2W into 3? with less than 1.0% THD.
Boomer audio integrated circuits were designed specifically to provide high quality audio while requiring a minimum amount of external components. The LM4938 incorporates a DC volume control, stereo bridged audio power amplifiers and a selectable gain or bass boost, making it optimally suited for multimedia monitors, portable radios, desktop, and portable computer applications.
The LM4938 features an externally controlled, low-power consumption shutdown mode, and both a power amplifier and headphone mute for maximum system flexibility and performance.
Note 1: When properly mounted to the circuit board, LM4938MH will deliver 2W into 4?. See Application Information section for more information.
Note 2: An LM4938MH that has been properly mounted to the circuit board and forced-air cooled will deliver 2.2W into 3?.
