公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有 325mW 扬声器放大器和 30mW 耳机驱动器的立体声音频 DAC
Audio input type Digital Input
Architecture Class-AB
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 3.6
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 8
Output power (W) 0.325
THD + N @ 1 kHz (%) 0.002
Iq (Typ) (mA) 4.6
Control interface SPI
Closed/open loop Closed
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 3.6
Sampling rate (Max) (kHz) 53
PSRR (dB) 56
Operating temperature range (C) -40 to 85
  • Low Power High Quality Audio DAC
  • Stereo Audio DAC Support Rates up to 48 ksps
  • High Quality 97-dBA Stereo Audio Playback Performance
  • Low Power: 11-mW Stereo Audio Playback at 48 ksps
  • On-Chip 325-mW, 8- Speaker Driver
  • Stereo Headphone Amplifier With Capless Output Option
  • Integrated PLL for Flexible Audio Clock Generation
  • Programmable Digital Audio Bass/Treble/EQ/De-Emphasis
  • Microphone and AUX Inputs Available for Analog Sidetone Mixing
  • Microphone Bias and Pre-Amp
  • SI? and I2S? Serial Interfaces
  • Full Power-Down Control
  • 32-Pin 5.5 mm QFN Package
  • APPLICATIONS
    • MP3 Players
    • Digital Still Cameras
    • Digital Video Camcorders
SPI is a trademark of Motorola.
I2S is a trademark of Phillips Electronics.
The TLV320DAC26 is a high-performance audio DAC with 16/20/24/32-bit 97-dBA stereo playback. The audio output drivers on the ?DAC26 are highly flexible, having software-programmable low or high-power drive modes to optimize system power dissipation. The outputs can be configured to supply up to 330 mW into a bridge terminated 8- headphone amplifiers in ac-coupled or capless output configurations, and can supply a stereo line-level output
A programmable digital audio effects processor enables bass, treble, midrange, or equalization playback processing. The digital audio data format is programmable to work with popular audio standard protocols (I2S, DSP, Left/Right Justified) in master or slave mode, and also includes an on-chip programmable PLL for flexible clock generation capability. Highly configurable software power control is provided, enabling stereo audio playback at 48 ksps at 11 mW with a 3.3-V analog supply level.
The ?DAC26 is available in a 32 lead QFN.
