公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
95mW 立体声模拟输入耳机放大器
Output power (W) 0.097
Analog supply (Min) (V) 1.4
Analog supply (Max) (V) 3.6
PSRR (dB) 70
Rating Catalog
Operating temperature range (C) -40 to 85
Headphone channels Stereo
Volume control No
Shutdown current (ISD) (uA) 0.01
Architecture Class-AB (ground-centered)
Iq per channel (Typ) (mA) 5.5
  • Ground Referenced Outputs
  • High PSRR
  • Available in Space-Saving TSSOP Package
  • Ultra Low Current Shutdown Mode
  • Improved Pop and Click Circuitry eliminates Noises During Turn-On and Turn-Off Transitions
  • 1.4 – 3.6V Operation
  • No Output Coupling Capacitors, Snubber Networks, Bootstrap Capacitors
  • Shutdown Either Channel Independently
Key Specifications
  • Improved PSRR at 1kHz: 70dB (Typ)
  • Power Output at VDD = 3V, RL = 16?, THD ≦ 1%: 95mW (Typ)
  • Shutdown Current: 0.01μA (Typ)
All trademarks are the property of their respective owners.
The LM4917 is a stereo, output capacitor-less headphone amplifier capable of delivering 95mW of continuous average power into a 16? load with less than 1% THD+N from a single 3V power supply.
The LM4917 provides high quality audio reproduction with minimal external components. A ground referenced output eliminates the output coupling capacitors typically required by single-ended loads, reducing component count, cost and board space consumption. This makes the LM4917 ideal for mobile phones and other portable equipment where board space is at a premium. Eliminating the output coupling capacitors also improves low frequency response.
The LM4917 operates from a single 1.4V to 3.6V power supply, features low 0.02% THD+N and 70dB PSRR. Independent right/left channel low-power shutdown controls provide power saving flexibility for mono/stereo applications. Superior click and pop suppression eliminates audible transients during start up and shutdown. Short circuit and thermal overload protection protects the device during fault conditions.
