公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
Dual, 32-V, 12-MHz, low noise (6.5-nV/√Hz) operational amplifier
Number of channels (#) 2
Total supply voltage (Min) (+5V=5, +/-5V=10) 4
Total supply voltage (Max) (+5V=5, +/-5V=10) 32
GBW (Typ) (MHz) 12
Slew rate (Typ) (V/us) 5
Rail-to-rail No
Vos (offset voltage @ 25 C) (Max) (mV) 3
Iq per channel (Typ) (mA) 3
Vn at 1 kHz (Typ) (nV/rtHz) 6.5
Features Standard Amps
THD + N @ 1 kHz (Typ) (%) 0.0005
Rating Catalog
Operating temperature range (C) -40 to 85
Output current (Typ) (mA) 10
Architecture Bipolar
CMRR (Typ) (dB) 110
Input bias current (Max) (pA) 500000
  • ±2-V to ±18-V Operating Voltage
  • 0.8-μVrms Low Noise Voltage
  • 12-MHz Gain Bandwidth Product
  • 0.0005% Total Harmonic Distortion
  • 5-V/μs Slew Rate
  • Drop-In Replacement for NJM4580
  • Pin and Function Compatible with LM833, NE5532,
    NJM4558/9, and NJM4560/2/5 devices
The RC4580 device is a dual operational amplifier that has been designed optimally for audio applications, such as improving tone control. It offers low noise, high gain bandwidth, low harmonic distortion, and high output current, all of which make the device ideally suited for audio electronics, such as preamplifiers, active filters, and industrial measurement equipment. When high output current is required, the RC4580 device can be used as a headphone amplifier. Due to its wide operating supply voltage, the RC4580 device can also be used in low-voltage applications.
