1 / 1
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  210粉丝
--- 产品详情 ---
3W 立体声、7.0V 至 15.0V 电源电压、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Stereo
Power stage supply (Max) (V) 15
Power stage supply (Min) (V) 7
Load (Min) (ohms) 16
Output power (W) 3
SNR (dB) 102.5
THD + N @ 1 kHz (%) 0.1
Iq (Typ) (mA) 11
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 7
Analog supply (Max) (V) 15
PSRR (dB) 60
Operating temperature range (C) -40 to 85
  • 3 W Into 16 From 12-V Supply
  • Volume Control for Speakers (BTL) and Headphones (SE)
  • Differential Inputs
  • Depop Circuitry
  • 1 μA Shutdown Current
  • Surface Mount Package
  • APPLICATIONS
    • LCD Monitors and LCD TVs
    • Multimedia Speakers
    • Notebook Computers
PowerPAD is a trademark of Texas Instruments.
The TPA6030A4 is designed to drive 3 W into 16- speakers using a surface-mount package without the need for an external heatsink. These features make it ideal for 15" ? 17" LCD monitors, small multimedia speakers, and notebook computers.
To simplify system design, the speaker volume level is adjusted by applying a dc voltage to the VOLUME terminal. The delta between speaker volume and headphone volume can be adjusted by applying a dc voltage to the SEDIFF terminal. To avoid an unexpected high volume level through the headphones, a third terminal, SEMAX, limits the headphone volume level when a dc voltage is applied. Integrated depop circuitry and the fully differential design minimize pops, clicks, and unwanted noise to provide a high level of audio performance.
The device is available in a 28-pin TSSOP PowerPAD? package. The PowerPAD? package is designed to transfer heat into the ground plane, eliminating the need for external heat sinks?minimizing solution cost and size.
