公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有关断模式的 350W 单声道、模拟输入 AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2
Load (Min) (ohms) 8
Output power (W) 0.35
THD + N @ 1 kHz (%) 1
Iq (Typ) (mA) 1.5
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 2
Analog supply (Max) (V) 5.5
Operating temperature range (C) -40 to 85
  • SOIC Surface Mount Packaging.
  • Switch On/Off Click Suppression.
  • Unity-Gain Stable.
  • Minimum External Components.
Key Specifications
  • THD+N at 1kHz, 350mW Continuous Average Output Power into 16? 10% (max)
  • THD+N at 1kHz, 300mW Continuous Average Output Power into 8? 10% (max)
  • Shutdown Current 0.7μA (typ)
All trademarks are the property of their respective owners. Boomer is a trademark of Texas Instruments.
The LM4818 is a mono bridged power amplifier that is capable of delivering 350mWRMS output power into a 16? load or 300mWRMS output power into an 8? load with 10% THD+N from a 5V power supply.
The LM4818 Boomer audio power amplifier is designed specifically to provide high quality output power and minimize PCB area with surface mount packaging and a minimal amount of external components. Since the LM4818 does not require output coupling capacitors, bootstrap capacitors or snubber networks, it is optimally suited for low-power portable applications.
The closed loop response of the unity-gain stable LM4818 can be configured using external gain-setting resistors. The device is available in SOIC package type to suit various applications.
