Output power (W) | 0.04 |
Analog supply (Min) (V) | 2 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 65 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Headphone channels | Stereo |
Volume control | No |
Shutdown current (ISD) (uA) | 0.1 |
Architecture | Class-AB |
Iq per channel (Typ) (mA) | 1 |
The LM4911/LM4911Q is an stereo audio power amplifier capable of delivering 40mW per channel of continuous average power into a 16? load or 25mW per channel into a 32? load at 1% THD+N from a 3V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4911/LM4911Q does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems. In addition, the LM4911/LM4911Q may be configured for either single-ended capacitively coupled outputs or for OCL outputs (patent pending).
The LM4911/LM4911Q features a low-power consumption shutdown mode and a power mute mode that allows for faster turn on time with less than 1mV voltage change at outputs on release. Additionally, the LM4911/LM4911Q features an internal thermal shutdown protection mechanism.
The LM4911/LM4911Q is unity gain stable and may be configured with external gain-setting resistors.
A Q-grade version is available for automotive applications. It is AEC-Q100 grade 2 qualified and packaged in a 10–pin MSOP package (LM4911QMM).
Key Specifications
PSRR at 217Hz and 1kHz | 65dB (typ) |
Output Power at 1kHz with VDD = 2.4V, 1% THD+N into a 16? load | |
Output Power at 1kHz with VDD = 3V, 1% THD+N into a 16? load | |
Shutdown Current | 2.0μA (max) |
Output Voltage change on release from Shutdown VDD = 2.4V, RL = 16? (C-Coupled) | |
Mute Current | 100μA (max) |
