公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有精密直流音量控制和耳机放大器的 750mW、立体声、模拟输入、AB 类音频放大器
Audio input type Analog Input
Architecture Class-AB
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 8
Output power (W) 1
THD + N @ 1 kHz (%) 0.6
Iq (Typ) (mA) 4
Control interface Hardware
Closed/open loop Closed
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 5.5
PSRR (dB) 50
Operating temperature range (C) -40 to 85
  • Precision DC Voltage Volume Control
  • Headphone Amplifier Mode
  • “Click and Pop” Suppression
  • Shutdown Control When Volume Control Pin Is Low
  • Thermal Shutdown Protection
Key Specifications
  • PO at 1.0% THD+N Into 8?; 750 mW (typ)
  • PO at 10% THD+N Into 8?; 1 W (typ)
  • Shutdown Current; 0.7μA(typ)
  • Supply Voltage Range; 2.7V to 5.5 V
All trademarks are the property of their respective owners.
The LM4875 is a mono bridged audio power amplifier with DC voltage volume control. The LM4875 is capable of delivering 750mW of continuous average power into an 8? load with less than 1% THD when powered by a 5V power supply. Switching between bridged speaker mode and headphone (single ended) mode is accomplished using the headphone sense pin. To conserve power in portable applications, the LM4875's micropower shutdown mode (IQ = 0.7μA, typ) is activated when less than 300mV is applied to the DC Vol/SD pin.
Boomer audio power amplifiers are designed specifically to provide high power audio output while maintaining high fidelity. They require few external components and operate on low supply voltages.
