公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有可选增益的 1.4W 单声道、模拟输入 D 类音频放大器
Audio input type Analog Input
Architecture Class-D
Speaker channels (Max) Mono
Power stage supply (Max) (V) 5.5
Power stage supply (Min) (V) 2.7
Load (Min) (ohms) 4
Output power (W) 1.4
THD + N @ 1 kHz (%) 0.8
Iq (Typ) (mA) 14
Control interface Hardware
Closed/open loop Open
Analog supply (Min) (V) 2.7
Analog supply (Max) (V) 5.5
PSRR (dB) 52
Operating temperature range (C) -40 to 85
  • No Output Filter Required for Inductive Transducers
  • Selectable Gain of 6dB (2V/V) or 12dB (4V/V)
  • Very Fast Turn On Time: 5ms (typ)
  • User Selectable Shutdown High or Low Logic Level
  • Minimum External Components
  • "Click and Pop" Suppression Circuitry
  • Micro-Power Shutdown Mode
  • Short Circuit Protection
  • DSBGA, WSON, and VSSOP Packages (No Heat Sink Required)
Key Specifications
  • Efficiency at 100mW into 8? Transducer 75%(typ)
  • Efficiency at 400mW into 8? Transducer 80%(typ)
  • Total Quiescent Power Supply Current (3V) 3mA(typ)
  • Total Shutdown Power Supply Current (3V) 0.01μA(typ)
  • Single Supply Range (VSSOP & WSON) 2.7V to 5.5V
  • Single Supply Range (DSBGA) (Note 11) 2.7V to 3.8V
All trademarks are the property of their respective owners.
The LM4665 is a fully integrated single-supply high efficiency switching audio amplifier. It features an innovative modulator that eliminates the LC output filter used with typical switching amplifiers. Eliminating the output filter reduces parts count, simplifies circuit design, and reduces board area. The LM4665 processes analog inputs with a delta-sigma modulation technique that lowers output noise and THD when compared to conventional pulse width modulators.
The LM4665 is designed to meet the demands of mobile phones and other portable communication devices. Operating on a single 3V supply, it is capable of driving 8? transducer loads at a continuous average output of 400mW with less than 2%THD+N.
The LM4665 has high efficiency with an 8? transducer load compared to a typical Class AB amplifier. With a 3V supply, the IC's efficiency for a 100mW power level is 75%, reaching 80% at 400mW output power.
The LM4665 features a low-power consumption shutdown mode. Shutdown may be enabled by either a logic high or low depending on the mode selection. Connecting the Shutdown Mode pin to either VDD (high) or GND (low) enables the Shutdown pin to be driven in a likewise manner to activate shutdown.
The LM4665 has fixed selectable gain of either 6dB or 12dB. The LM4665 has short circuit protection against a short from the outputs to VDD, GND or across the outputs.
