Output power (W) | 0.105 |
Analog supply (Min) (V) | 2 |
Analog supply (Max) (V) | 5.5 |
PSRR (dB) | 70 |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
Headphone channels | Stereo |
Volume control | No |
Shutdown current (ISD) (uA) | 0.4 |
Architecture | Class-AB |
Iq per channel (Typ) (mA) | 0.65 |
- Active-High Shutdown Mode
- WSON, VSSOP, and SOIC Surface Mount Packaging
- "Click and Pop" Suppression Circuitry
- Low Shutdown Current
- No Bootstrap Capacitors Required
- Unity-Gain Stable
Key Specifications
- THD+N at 1kHz, 105mW Continuous Average Power into 16? 0.1 % (typ)
- THD+N at 1kHz, 70mW Continuous Average Power into 32? 0.1 % (typ)
- Shutdown Current 0.4 μA (typ)
All trademarks are the property of their respective owners.
The LM4810 is a dual audio power amplifier capable of delivering 105mW per channel of continuous average power into a 16? load with 0.1% (THD+N) from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4810 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems.
The unity-gain stable LM4810 can be configured by external gain-setting resistors.
The LM4810 features an externally controlled, active-high, micropower consumption shutdown mode, as well as an internal thermal shutdown protection mechanism.
