公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  184粉丝
--- 产品详情 ---
具有数字音量控制的 105mW 立体声、模拟输入耳机放大器
Output power (W) 0.105
Analog supply (Min) (V) 2
Analog supply (Max) (V) 5.5
PSRR (dB) 60
Rating Catalog
Operating temperature range (C) -40 to 85
Headphone channels Stereo
Volume control Yes
Shutdown current (ISD) (uA) 0.3
Architecture Class-AB
Iq per channel (Typ) (mA) 0.65
  • Digital Volume Control Range from +12dB to ?33dB
  • WSON and VSSOP Surface Mount Packaging
  • "Click and Pop" Suppression Circuitry
  • No Bootstrap Capacitors Required
  • Low Shutdown Current
Key Specifications
  • THD+N at 1kHz, 105mW Continuous Average Output Power into 16? 0.1 % (typ)
  • THD+N at 1kHz, 70mW Continuous ?Average Power into 32? 0.1 % (typ)
  • Shutdown Current 0.3 μA (typ)
All trademarks are the property of their respective owners.
The LM4811 is a dual audio power amplifier capable of delivering 105mW per channel of continuous average power into a 16? load with 0.1% (THD+N) from a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. Since the LM4811 does not require bootstrap capacitors or snubber networks, it is optimally suited for low-power portable systems.
The LM4811 features a digital volume control that sets the amplifier's gain from +12dB to ?33dB in 16 discrete steps using a two?wire interface.
The unity-gain stable LM4811 also features an externally controlled, active-high, micropower consumption shutdown mode. It also has an internal thermal shutdown protection mechanism.
